Hint:
20.5.2013: JKuehn: create the article page
22.10.2013: work-in-progress by UPrenner
23.10.2013: UPrenner article ready, just update of pictures
If you are a native speaker, please Help us and review this article
| Figure 1: DMXControl Program icon |
Once DMXControl starts by double clicking the program icon, (see figure 1) DMXControl's control bar opens (see figure 2).
This window give the operator easy access to all the main modules, tools and configurations of DMXControl. In addition, other configuration setting are available with the menu items « File » « Window » « Configuration » and « ? ».
There is also a status line which displays the path and the file of the loaded project and also the approximate load of DMX Control's internal message system on the lower window edge window. In addition, the date, the current system time and the version number are also shown.
| Figure 2: The control center of DMXControl |
- to open, save and quit your show (menue « File »)
- to get all your tools from DMXControl (menue « Window »)
- to setup your system (menue « Settings »)
- to call the support funktions (menue « ? »)
Control elements
The FILE Menu
The standard Windows items are located in the FILE menu.
| Icon | Menue item | Shortcut | Description |
| New project... | n.a. | Start a new project. | |
| Open project... | n.a. | Open an existing project. | |
| Save project | CTRL+S | Overwrites the currently selected project. | |
| Save project as... | n.a. | Save the project in a selected directory. | |
| Pack & Go... | n.a. | Archiving a complete project, e.g. to move it to a new or second computer. (see chapter 31) | |
| Exit | n.a. | Quits DMXControl and displays the usual safety and exit queries. |
The WINDOW Menu
The 'Window' menu includes many important items to DMXControl, Any installed Plugins are also shown here.
First arrangement
| Channel overview | n.a. | Opens the channel overview window. (see chapter 8) | |
| Devices | n.a. | Opens the device window to managing your devices. (see chapter 6) | |
| Graphical view | n.a. | Opens the graphical view. (see chapter 5) | |
| Group selection | n.a. | Opens the group selection window. (see chapter 5) |
Second arrangement
| BeatTool | n.a. | Opens the BeatTool window for sound-to-light-steering. (see chapter 15) | |
| Command line | n.a. | Opens the command line window. (see chapter 20) | |
| Command Box | n.a. | Opens the command box. (see chapter 16) | |
| DMXIn remote control | n.a. | Opens the DMXIn remote control for activating the DMXIn remote control. (see chapter 28) | |
| Joystick control | n.a. | Opens the window for setup the joystick control. (see chapter 26) | |
| Midi remote control | n.a. | Opens the Midi remote control for activating the Midi remote control. (see chapter 27) | |
| Keyboard control | n.a. | Opens the Keyboard control window for activating the Keyboard control. (see chapter 25) | |
| Master | n.a. | Opens the master window with the master fader. (see chapter 13) | |
| PDA remote control | n.a. | Opens the window for PDA setup. (see chapter 24) | |
| Scheduler | n.a. | Opens the scheduler window. (see chapter 21) |
Third arrangement
| Audio player | n.a. | Opens the audio player window. (see chapter 17) | |
| Chasers Tool | n.a. | Opens the chasers tool window. (see chapter 11) | |
| Cue List | n.a. | Opens the cue List window. (see chapter 10) | |
| Sound analyzer | n.a. | Opens the sound analyzer window for sound-to-light setup. (see chapter 14) | |
| Submaster | n.a. | Opens the submaster window. (see chapter 12) | |
| Textbook | n.a. | Opens the textbook window. (see chapter 19) | |
| Timecode player | n.a. | Opens the timecode player window. (see chapter 18) |
Fourth arrangement
| Show cue libary | STRG+B | Opens the cue libary window. (see chapter 9) | |
| Edit view | STRG+E | Hides menu items for live operating. | |
| Fetching all windows on the primary desktop. | n.a. | If you work with several monitors, it can happen on the return to the single monitor mode that windows are still on the now virtual monitor. With this function, you can get missing windows back to your primary monitor. It is premiss that the window is open. |
The menu items which serve the configuration of DMXControl and his modules are in the menu configuration.
| Output plugins.. | n.a. | Opens the window for setup and configure the output plugins. (see chapter 7) | |
| Plugins.. | n.a. | Opens the window for setup and configure the plugins for advance functions. (see chapter 30) | |
| Program settings... | n.a. | Opens the program settings window. (see chapter 29) | |
| Midi remote control... | n.a. | Opens the window for configure the Midi remote control. (see chapter 27) | |
| DMX-In remote control... | n.a. | Opens the window for configure the DMX-In remote control. (see chapter 28) | |
| Joystick control... | n.a. | Opens the window for configure the joystick control. (see chapter 26) | |
| Keyboard control... | n.a. | Opens the window for configure the keyboard control. (see chapter 25) | |
| Color lists... | n.a. | Opens the window for definition the color lists. (see chapter 6) | |
| Gobo lists... | n.a. | Opens the window for definition the gobo lists. (see chapter 6) | |
| Shape editor... | n.a. | Opens the window of the shape editor for the motion cue. (see chapter 23) | |
| Englisch Deutsch |
n.a. | Language selection for DMXControl. | |
| Enable experimental tools | n.a. | If this menu item is select, then the program parts which weren't tested substantially yet and are in the beta stage still appear, too. No experimental program parts are integratedly in the 2.12 at the moment, only some of Plugins need this point so that they are shown in. (e. g. the Plugin BeatDetection) |
The menu items which help you with DMXControl's operation are in the menu help.
Other controls in the control center
General controls in DMXControl
Module commands
This module commands refers essentially to the button blackout and freeze.
- Module: DMX-Output
- Meaning from Device/Function and Channel
| Blackout | The Blackout command refers to the Blackout icon in the control center and in the graphical view. | Toggle | The command Toggle inverted the momentary behaviour of the Blackout-Funktion. |
| On | The command On activate the Blackout-Funktion. | ||
| Off | The command Off deactivate the Blackout-Funktion. | ||
| Freeze | The Freeze command refers to the Freeze icon in the control center and in the graphical view. | Toggle | The command Toggle invertst the momentary behaviour of the Freeze-funktion. |
| On | The command On activate the Freeze-funktion. | ||
| Off | The command Off deactivate the Freeze-funktion. |
Meaning of the Flags:
Tip(s)
Projects should regularly be stored to be on the safe side in the construction phase particularly also under another name to be able to go back to an older version if necessary. The experimental program parts seem only in the menu when under configuration the corresponding option was chosen (e. g. new tools into the beta test phase).
