DDF DMXC2
From English DMXC-Wiki
Revision as of 13:46, 10 November 2013 by Steiny (talk | contribs) (→‎Slider)
Template:Chaptertitle DMXC
VLC icon.png This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page.
Hint:
07.11.2013 UPrenner: work-in-progress
Arrow back.png Pack And Go Function
Contents
Picture 1: Grafische Bühnenansicht mit DDF-Icon
Picture 2: Geöffnetes DDF-Fenster mit Steuerelementen
DDF is the abbreviation of Device Definition File. The DDF are the device description (Fixtures) in DMXControl, they serve to inform DMXControl about the functions of the attached DMX device to this. In the DDF the number becomes this one how channels of the DMX device defined and as well these use possible control elements:
  • Position input control element e.g. at Movingheads and Scanners.
  • RGB or CMY color choice control element to the color mixture at e.g. LED headlight or color mixed units at Movingheads.
  • Dropdown control elements
  • Button control elements.
Become the DDF in the « graphical view » with an icon of the device shown (see figure 1), then also can here be accessed the icon, the DDF window by a click with the control elements (see figure 2). XML format which is translated by DMXControl into the internal device description is carried out the description the DMX equipment in one. The DDF are found the DMXControl main directory in the sub-folder DEVICEs. The accompanying icon pictures, which one in the & laquo; Graphic stage view & raquo; be, lie in another sub-folder named shown images.
You get prefabricated DDFs, which weren't enclosed at the installation, can you perhaps of the DMXControl home page in the device library[1]. DDF can be made in a simple way with a XML editor (e. g. PSPad[2]) or also with the DDFCreator. There are advantages and disadvantages with the DDFCreator as also the construction of a DDF with a XML editor. With a XML editor, paraphrasing an existing DDF can be managed considerably faster than with the DDFCreator, against this one is fundamentally faster with the DDFCreator at the construction of a new DDF surface with slidern, button etc.
At both one needs a corresponding knowledge to make an operating DDF no matter whether one now the DDFCreator preferred or the XML editor. Shall the following chapters be conveyed for you, this knowledge among other things the language reference serves as a reference book
Description
A very common language syntax which e.g. is also used in the other dialects at web pages or WAP in the Internet sides is XML (eXtensible Markup Language). But you don't have to be an expert to make a new device description too manually. The following simple notes suffice:
Please take care that your editor doesn't store any (invisible) control characters. There won't be any problems at the Windows editor or PSPad. If you want to use Word or similar software, you should save the file in the raw document format (*.txt).
  • The DMXControl dialect of XML requires for every opening tag always one (<tag>) closing (</tag>) tag. Only this one gets the last level completed just by implication day (e. g. <item caption= "white" value="0" />).
  • The final signs /> and </tag> are semantically equivalent, also <item caption="white" value="0" > </item> is valid in this case.
  • Every day can have attributes which you find professed in the table below. Every attribute value is started with an equals sign and the value must always be included in double apostrophes.
  • All day and attribute identifiers are noted down at DMXControl in a small letter.
  • The day has to be defined hierarchically. They also should make this recognizable about corresponding indents.
  • As a rule, not cares about the order of the attributes of a day. Where it for once depends on the order anyway, you describe below explicitly.
  • Comment are noted down in the form <!- This is a comment —>.
  • E.g. you can have a look at xml files (therefore also the DMX DEVICEs files) in open form with the Internet Explorer.
So it was already this - we have a look at a simple example.
Example: dimmed spotlight
Every device should get an apt icon to receive an adapted representation in stage representation. This icon will be find in the subdirectory Images (Root:\Programme\DMXControl\Devices\Images).
 Important Hint The icons afterwards still can be changed in DMXControl. (In the context menu of the graphical view).
The preceding line numbers of the following XML example file cannot be inserted; they serve only the description of the example:
3   <channels>
4     <function channel="0" minvalue="0" maxvalue="255" name="Intensity" fade="yes" />
5   </channels>
11  </form>
12 </device>
Row   1 the Parser will informed about the used XML version.
Row   2 the global description of the new type of device defines inclusive reference to the icon to be put and one ( initialization of the device the optional initsequence was demonstrated here, is but at a headlight only conditionally appropriately. The dimmer channel is (50%) ) put on DMX value 128 at the initialization here.
Row   3 the DMX channels of the device are defined between line 3 and 5.
Row   4 the channel description of the first channel is. This is always the channel numbers at zero important begin, i. e. the first channel is channel="0". In addition, other parameters as well as the channel name are still put here.
Row   6 the lines 6-9 describe the form, that is this one, to graphic coordinates in the context menu for the device picture, names and start address in the unity „Pixel“.
Row 10 here the operating devices follow a slider with his graphic coordinates and the assignment to the channel in question with her qualities, in this example now. Operating devices like radio badges also could, drop down or badges are declared for other types of device here.
Picture 3: Dimmer-DDF
Three button become Pinup button, Move button, Close button will be generatedly per default generatedly on the top right side (see figure 3).
Create a DDF
Before you make a new DDF, please have a look on our webside in the device library whether a suitable or similar already give it to definitions for your device. To make a new DDF, you modify an existing DDF of a similar device best. This goes text been based change considerably faster than with the DDF Creator just with this. If you have completed your work, you simply put the xml file in the subdirectory in the DMXControl list „DEVICEs“himself has in your DMX installation as of and store the corresponding gif picture (in the format 32 x32 pixels, the transparency fashion proves itself) in the subdirectory „images“in this „DEVICE“List-. The device should be visible at the next start of DMXControl so.
Syntax overview
Every description contains four main parts (see figure 4):
  • Description of global qualities device (in the example dimmed spotlight line 1-2)
  • Description of the individual DMX channels channels (in the example dimmed spotlight line 3-5)
  • Description of the graphic context menu form (in the example dimmed spotlight line 6-11)
  • Prozedure code (not contained, optionally in the example)
Picture 4: Basic structure of a DDF
All form elements must on the will provide DDF form with graphic coordinates to the positioning. The elements „Label“ and „Line“ are passive and serve only the design of the surface. The remaining active elements of the form (also control element mentioned, e.g. on/off) can be used for the active control of the DMX device.
Graphical elements
The figure 5 shows a survey of all supported graphic elements. An assignment to the required syntax elements is carried out in the explanation texts.
Picture 5: Graphic elements
The following figure 6 illustrates the meaning of the graphic coordinates of the control elements:
Picture 6: Graphic coordinates of the control elements
Functional elements
The active control elements interact in 3 possible concepts with DMXControl or the device in which exactly one concept is selected at the definition of a concrete control element:
Konzept Beschreibung Beispiel
1 Channel/Value concept The control element is assigned via the channel attribute to a concrete channel. Concrete values or ranges of values which are put at the activity of the control element are defined in the control element. - option list
  caption="Star sky" value="165"
- Value range of the slider
2 Sequences An instruction consequence which is executed when operating is defined in the control element as a string. clicksequence=
“set 1 75; set 2 100“
3 Action/Procedures A separately defined procedure contains more complex program instructions. The procedure is operate assigned via the action attribute and at everybody the control element executed. action="SetGobo"
This which Channel attribute and the action attribute can want to use alternatively in the control elements particularly means.
 Important Hint For many applications the first two concepts are sufficient.
Like the complexity and cardinality of the 3 concepts grows, the running time requirements also increase. The simplest variant on the solution of a task should therefore always be chosen. Also at the channel description an action attribute can be used. This means that the procedure is called at every change of the channel value. In figure 7 an example is shown how different control elements can interact with the channels. „So like the complexity and channel_n“address and can over the 3 mentioned above concepts be put. The current value, obliged to it for a control element are, are addressed more than one name freely eligible for office (reference) assigned to the control element here „control_n“bezeichnet. Im following example is for three control elements „Actionses“and additional „Reference names“assigned. And therefore should, as a rule these Actionses be able to do one or put several Channel values „set name“being described. Furthermore there is one „action“ assigned to the channel_3. This is intended to read and to inform about to the control elements the current channel values „assigned to the channel_3. Scheduled, this one are Get name this for this“get since she must read current channel values.
Picture 7: Interaction of control elements
 Important Hint The markings of the buttons don't have a meaning here.
Syntax
This chapter describes the syntax of the device and form configuration files of DMXControl.
Generic attributs
 Important Hint Attributes often recurring are described to it globally once for the shortening with the same meaning after the following tables here.
Reference Attribute Hierachie and properties Notice Example
GP1 value Assigned DMX value byte 0, 128, 255
GP2 caption Descriptive enumeration value.
Explanatory name for an attitude.
string Dimmer,
Strobe,
usw.
GP3 top Relative x-coordinate of the
element of the left upper corner
integer top=“150“
GP4 left Relative x-coordinate of the
element of the left upper corner.
integer left=“100“
GP5 width Width of the element integer width=“80“
GP6 height Height of the element integer height=“30“
 Important Hint All coordinate details (top, left, width, height) are indicated in pixel.
Device description
Tag Attribute Hierachie and properties Notice Example
<device> Level 1
image Icon filename. string,
initsequence Sets initial values for the individual DMX channels of the device Optional use e.g. for scanner/moving head's start position set 0 15;
set 7 128;
<information> Level 2
Supplementary comment.
<name> Level 3
Arbitrary text.
Custom Scanner
<vendor> Level 3
Arbitrary text
(manufacturer).
optional Showtec
<deviceidentifier> Level 3
Arbitrary text
(manufacturer identifier.
optional TG-3
<author> Level 3
Arbitrary text
(originator).
optional
<comment> Level 3
Arbitrary text
(comment).
optional
<help> Level 2
Help text (ASCII).
optional
Channel description
<channels> Level 2
For every DMX channel is one
<function>”-part to define
<function> Level 3
Subtag from “<channels>
channel Internal DMX channel number
channel no. must always of 0
climbing without interruption be
defined for the individual channels
integer
minvalue Minimal DMX value integer
maxvalue Maximal DMX value integer
name Descripting name
for the channel.
string Intensity
fade Channel fading string yes,no
type Channel typ
Important for the internal
data handling
string dimmer, r,g,b,
pan, panfine,
tilt, tiltfine,
color, gobo
action Call of a procedure at
string
optional
<virtual> Level 3
<channel> Level 4
Subtag from “<virtual>
The three rgb channels assigned to the virtual dimmer
integer
 Important Hint The channel type (type) also should allocate channel for everybody
become provided that this channel to the type matches. E.g. it doesn't make sense to describe every channel as a dimmer.
dimmer reserved for channels these regulate the intensity
r,g,b reserve for channels of RGB LED equipment, r for the red channel, g for the green channel, b for the blue channel. On the one hand, r, g, b are for the type it HAL needs in DMXControl. This also means, this in the graphical view the colors of the spotlights be shown.
One can one racks use this in the program configuration under « graphical view » and then at « symbol » « representation of the colors instead of graphic ».
On the other hand, the type also for the one into the 2.12 new one LED's run light generator required becomes.
a,w reserve for channels of (RGB)A as and (RGB)W LED devices, a for the amber channel, W for the white channel. The type a and w aren't supported by DMXControl yet the device, however, is appropriately since amber or white channel make a bigger and bigger contribution to the market and therefore perhaps are supported by DMXControl soon, too with additional.
pan, panfine reserve for the Pan channels of scanners, moving heads or similar equipment. How pan is and panfine assigned to the channel for the rough control the channel for the fine control at 16 bits of device.
tilt, tiltfine as in the case of pan and panfine but for the tilt axis.
color, gobo The appropriate Farb and Goborad channels can be assigned to (importantly to color & gobo lists)
reserved for CMY devices, c for the cyan channel, m for the magenta channel, y for the yellow channel. The type c, m, y aren't supported by DMXControl make sense, however, yet.
other all other channels don't need a type description
 Important Hint The ones for RGB devices reserved type's are important the HAL (Hardware Abstraction Layer) since version 2. 11 in which then be able to the adjusted colors of the spotlight, be represented in the graphical view too. Also for version 2.12, here they also are needed for the RGB running light generator.
Menue description
<form> Level 2
Subtag from “<device>
width
height
See generic attribute
GP5; GP6
integer
<deviceimage> 'Level 3
Subtag from “<form>“;
Absolute position of
the shown picture
top
left
width
height
GP3 bis GP6
integer
<devicename> 'Level 3
the shown name
top
left
width
height
GP3 bis GP6
integer
<deviceaddress> 'Level 3
Subtag von “<form>“;
the shown base address
top
left
width
height
GP3 bis GP6
integer
Control elements
Position control
DMXC2 Manual DDF position field cartesian.png  DMXC2 Manual DDF position field polar.png
<position> Level 3
Creates a positioning
field for positioning from
scanners or moving heads.
By a click on the button down on the right in the DDF you can switch between a cartesian and polar positioning.
top
left
width
height
GP3 bis GP6
integer
 Important Hint The position pointer can be placed by initsequenz
Slider
<slider> Level 3
Creates a slider
top
left
width
height
GP3 bis GP6
integer
channel assigned channel
alternative for action
integer
optional
startvalue Value range of the
Slider (lower value)
integer startvalue="0"
endvalue Value range of the
Slider (uper value)
integer endvalue="255"
tickfreq Scaling, distance of the
scale subdivision
integer tickfreq="32"
smallchange Change rate e.g. at the
up down keys
integer
(VB-properties)
smallchange="20"
largechange Change rate e.g. at the
mouse click (not draged)
integer
(VB-properties)
largechange="50"
name Referenz name for procedure
code (variable name)
string
optional
StrobeSpeed
change at the Slider
alternative channel
string
optional
SetSpeed
Dropdown
<dropdown> Level 3
Subtag from“<form>“;
Creates a dropdown menu.
top
left
width
GP3 bis GP5
integer
channel Assigned channel
integer
optional
string
optional
Gobo
change of a dropdown
entries, alternative zu channel
string
optional
SetGobo
<item> Level 4
Subtag from “<dropdown>
caption Explanatory name string Clear
value DMX value for caption integer value="0"
minvalue
maxvalue
Value range for caption for
the diplayed of the dropdown entry.
integer minvalue="10"
maxvalue="26"
color Show a square with the assigned color before caption. hex color="#ff0000"
Color Red
<colorlist> Level 4
All entries of the in color list assigned to the device insert.
optional a substitute/
addition for
Item
<gobolist> Level 4
Subtag from“<dropdown>
All entries of the in gobo list assigned to the device insert.
addition for
Item
Options
<options> Level 3
Erzeugt ein Radiobuttonfeld
top
left
Siehe Generische Attribute
GP3 & GP4
integer
channel Zugeordneter Kanal
alternativ zu action
integer
optional
Auswahl eines Radiobuttons,
alternativ zu channel
optional SetGoboSpeed
code (Variablenname)
string
optional
GoboSpeed
<option> Level 4
Subtag von “<options>
GP2
string off
top
left
GP3 & GP4, relative Position
zur Position von “<options>
integer left="0"
top="0"
On/Off-Button
<onoff> Level 3
Erzeugt einen Button als Schalter
top
left
width
height
GP3 bis GP6
integer
integer
optional
betätigen des Buttons
string
optional
SetLampOnOff
string
optional
LampOnOff
color Hex RGB-Farbwert des Button hex color="#00ff00"
Farbe Grün
onvalue DMX-Wert für Button ON integer onvalue="150"
offvalue DMX-Wert für Button OFF integer offvalue="0"
ausgeführt wird
string "set 0 230;
set 1 25"
ausgeführt wird
string "set 0 0;
set 1 0"
Command-Button
<command> Level 3
Erzeugt Button’s als Taster
top
left
width
height
GP3 bis GP6
integer
string
optional
SetReset
string
optional
Reset
caption Erklärender Name string Reset
color Hex RGB-Farbwert des Button string color="#0000ff"
Farbe Blau
startende Aktivität ist im
Attribut spezifiziert
string "save 0;
set 0 230;
hold 5500;
restore 0"
string "save 0;
set 0 230;
hold 5500;
restore 0"
upsequence Beim Loslassen zu
string "save 0;
set 0 230;
hold 5500;
restore 0"
Colorpicker
<colorpicker> Level 3
Erzeugt einen Colorpicker.
top
left
width
height
GP3 bis GP6
integer
Rot oder Cyan,
integer
optional
Grün oder Magenta,
integer
optional
Blau oder Yellow,
integer
optional
string
optional
ColRGB
Änderung einer Farbe,
alternativ zu channel1-3
string
optional
SetColRGB
oder CMY
string mode=“cmy“
layout Auswahl von zwei
verschiedenen Layouts des
Colorpickers
integer layout="1"
Beispiel:
 Important Hint Bitte halten Sie die Maustaste gedrückt, wenn Sie über das Dropdown-Menü die Einstellung im Farbbalken ändern wollen. Eine Direkteingabe des numerischen Wertes ist ebenfalls möglich.
Passive design elements
<line> Level 3
Gestaltungselement;
Erzeugt eine Linie.
x1; y1 Startkoordinate der Linie integer
x2; y2 Endkoordinate der Linie integer
<label> Level 3
Gestaltungselement;
zusätzliche Beschreibung
eines Bedienelementes.
top
left
width
height
GP3 bis GP6
integer
caption Anzuzeigender Text string CMY Mischung
Beispiel: miniatur|zentriert|600px|Bild 8: DDF Giotto Spot 400
Template:BoxReferenz
Help
miniatur|zentriert|600px|Bild 9: Hilfemenü eines DDF's
Sequences
Operation Bedeutung Beispiel
save >channel< Zwischenspeichern des aktuellen Kanal-
"save 0; set 0 230; hold 5500; restore 0"
>value<
hold >time< Timer (wartet >time< in msec.) "save 0; set 0 230; hold 5500; restore 0"
Procedurs (advanced programming options)
General principles
Basic syntax elements and conventions
Operation Bedeutung
! beginnt einen Befehl
 $ beendet einen Befehl
Operation Bedeutung
 + Addition
 - Subtraktion
 * Multiplikation
 / Division
 mod Modulo-Operation
Operation Bedeutung
den Wert des Ausdruckes >val<
> > |gt| größer
< < |lt| kleiner
= &eq; |eq| gleich
 Important Hint Die Prozedur “INITCONTROLS” wird beim Öffnen der Form ausgeführt, um die Controls auf die Werte zu setzten, die durch die aktuellen DMX-Werte vorgegeben werden. Darin sollten also nur "Get"-Funktionen aufgerufen werden! Initcontrols muss nicht definiert sein, ist aber empfohlen, damit die Controls immer den aktuellen Zustand des Gerätes abbilden.
XML syntax of the procedure code
<code> Level 2
Subtag von "<device>"
enthält alle Proceduren
<procedure> Level 3
Subtag von "<code>"
enthält den Code der Procedure
An example prozedure
Dieses Beispiel zeigt eine Prozedure, die die Werte der Steuerungselemente „color_color“ und „color_speed“ eines Movingheads in Abhängigkeit vom aktuellen DMX-Wert des Kanals 2 (Farbwechsler) setzt. Der Mac 250+ hat 4 Möglichkeiten für das Farbrad:
action="GetColor"/>
<procedure name='GetColor'>
Procedure GetColor( )
!if|{channel_2} &lt; 208|
  !set_control|color_color|
  {channel_2}$
  !set_control|color_speed|0$
({channel_2} &lt; 227)|
  !set_control|color_color|-1$
  (226-{channel_2})$
({channel_2} &lt; 246)|
  !set_control|color_color|-2$
  ({channel_2}-227)$
({channel_2} &lt; 256)|
  !set_control|color_color|-3$
  ((255-{channel_2}) * 2)$
begin
if channel_2 < 208 then
  color_color := channel_2;
  color_speed := 0;
(else)
if (channel_2 > 207)  and
(channel_2 < 227) then
  color_color := -1;
  color_speed := 226-channel_2;
(else)
if (channel_2 > 226) and
(channel_2 < 246) then
  color_color := -2;
  color_speed :=channel_2-227
(else)
if (channel_2 > 245) and
   (channel_2 < 256) then
  color_color := -3;
</procedure>
end
Tip(s)
Links and references
Contents
