| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 13:46, 15 November 2013 (UTC) 4599 days ago. |
Hint:
12.11.2013 UPrenner: work-in-progress
Command overview
Commands are a powerful concept in DMXControl. Originally develops it turned out to trigger certain actions by external input devices (MIDI controller, computer keyboard) that the internal communication also profits from the command concept between modules.
Some examples of commands:
- Fade in a cue
- Causing a blackout
- Start a chaser tool
- Flash a Submasters
Typical appearance of commands:
- in a cue expiry of the cue list
- assignt to the buttons of the commabd box
- started in the audio player or in the text book module
- used into chasers
- assigned into movement cues to the individual figure points
- the original purpose: the integration of hardware operating devices
Almost every module in DMXControl offers commands of its own that otherwise keyboard or mouse intensive processes can much be automated now which means. The commands available are explained in the command overview.
Certain processes need a parameter value (for example "factor of the acceleration" etc. ) in addition to the command, either this one definitely agrees in the command authority or (if the flag ask for value is set) is questioned by dialog box.
| Figure 1: Window for creating a command |
The flag toggle has influence on the behavior of puh buttons (on external controllers) or buttons (e.g. in the commando box). The Control which means a click switches on the Control either or turns off is put into a so-called Toggle mode depending on previous condition. One can hereby button at a MIDI keyboard an effect be assigned, for example, either this one runs either as long as the button is held (Toggle-Flag off) or as long as another time is pushed to the button (Toggle-Flag on).
Being able to become certain functions with commands within DMXControl triggered. This chapter delivers a survey of all commands.
General
An order has the basic structure: <Module> - <Device/Functions> - <Channel> - <Flag> -<Value>
- <Module> the mentioned object (ageneral a tool) which shall execute this one is
- <Funktionen> the provided methods/actions or "sub-objects" of the module are, of course they are different depending on a select module
- <Kanal> either an attribute or the operation at sub-objects is
- <Flag> describe the attitudes of the command
- <Wert> submits a parameter to the attribute or the operation
The command entry is supported at the petition by the GUI surface by only the possible values turning up for the choice always.
Flag
4 flags can be put parallel here:
- Toggle mode - This flag has influence on the instruction execution. Commands are usually executed by buttons when pushing and relase (respectively with corresponding value). The toggle mode suppresses the execution when letting off so that e.g. an active effect remains switched on up to the next keystroke.
- Use specified value - This flag is, whether this one specified instead of the real (e.g. of DMXIn) shown off with fed value shall be used.
- Ask for value - A dialog box appears to enter the value to the running time. E.g. this can make sense at the call of commands over the keyboard or command box to avoid many uniform commands which are different only by a value.
- Ignore value 0 - With this parameter the function of "letting off" can be stopped if the value 0 results from it. An command with this flag only can be concluded by another command or be overwritten by other values at times. For example: Unlike the toggle mode the active effect also remains after let off active the button and another keystroke cannot be switching off again either.
Device/Functions
Defaults with the following generic meaning methods appear at objects, also which offers a register, lists or drop down choice of elements (e. g. audio player -> track, scene list -> list, chasers-> chase) here besides the dynamic ones:
- Selected - das gerade aktuelle Element wird angesprochen
- Next - das folgende Element in der Liste wird angesprochen
- Previous - das vorige Element in der Liste wird angesprochen
- --- (Separator) - no function
Channel
If start/stop is chosen, the respectively complementary operation is carried out for the action just executed.
Value
The values are expected standardizedly from 0. 000 to 100. 000, so one must imagine the petition in per cent values. It is supported for finer dissolvings up to three fractional digits. |
Module Command
As described above, every module supports different orders.
Audio
| Kanal 1-16 | Auswahl eines der 16 Audiokanäle auf die der weitere Befehl angewendet wird. | Pause | Hält den unter Gerät/Funktion ausgewählten Kanal an, nach erneuten Aufruf wird die Kanalausgabe forgesetzt. |
| Zurückspulen | Spult das Soundfile zum Anfang zurück. | ||
| Stop | Stop das Soundfile. | ||
| Lautstärke setzen | setzt die Lautstärke duch Übernahme des angegebenen Werts. |
Audiotrack
Start/Stop | Der Befehl Start/Stop startet und stopt den ausgewählten Audiotrack zur Wiedergabe. (Der Befehl sollte im Zusammenhang mit dem T-Flag eingesetzt werden.) |
| Stop | Der Befehl Stop stopt den ausgewählten Audiotrack zur Wiedergabe. | ||
| zurück Spulen | Durch den Befehl zurück Spulen Springt der Audio-Cursor wieder an de Anfand des Soundfiles. | ||
Der weitere Befehl wird auf die aktuell nächste, vorherige oder im Dropdown benannten Audiotrack angewendet. | Auswählen | Wählt die nächste, vorherige bzw. die im Dropdown Gerät/Funktion benannten Audiotrack aus. |
| Start/Stop Start Stop zurück Spulen |
siehe oben |
Beattool
| Tap-Button | Der Befehl (Kanal) wird auf den TAP-Button im BeatTool angewand. | Auswählen | Der Tap-Button wird ausgewählt (betätigt). |
| Sync-Button | Der Befehl (Kanal) wird auf den Sync-Button im BeatTool angewand. | Auswählen | Der Sync-Button wird ausgewählt (betätigt). |
| Reset-Button | Der Befehl (Kanal) wird auf den Reset-Button im BeatTool angewand. | Auswählen | Der Reset-Button wird ausgewählt (betätigt). |
DMX-Ausgabe
| Blackout | Der Blackout-Befehl bezieht sich auf das Blackout-Icon im Steuerzentrum und in der grafischen Bühneansicht. | Umschalten | Der Befehl Umschalten invertiert den momentanen Zustand der Blackout-Funktion. |
| Ein | Der Befehl Ein aktiviert die Blackout-Funktion. | ||
| Aus | Der Befehl Aus deaktiviert die Blackout-Funktion. | ||
| Freeze | Der Freeze-Befehl bezieht sich auf das Freeze-Icon im Steuerzentrum und in der grafischen Bühneansicht. | Umschalten | Der Befehl Umschalten invertiert den momentanen Zustand der Freeze-Funktion. |
| Ein | Der Befehl Ein aktiviert die Freeze-Funktion. | ||
| Aus | Der Befehl Aus deaktiviert die Freeze-Funktion. |
DMXIn-Remote
| Bank | Bei Auswahl dieser Funktion, besteht die Möglichkeit über den Befehl auf die verschiedenen Bänke,in der DMX-Fernsteuerung, zuzugreifen. | Nächste | Wählt die nächste Bank aus. |
| Vorherige | Wählt die vorherige Bank aus. | ||
| Bankname | Direkte Auswahl der definierten Bänke über Bankenamen. |
Effekte
| Alle | Der Befehl wird auf alle Effekte angewand. | Stop | Alle laufenden Effekte werden gestopt. |
| Ausgewählter | Der weitere Befehl wird auf den aktuellen Effekt angewendet. Oberhalb einer Effektkategorie stehen, wenn Kategorien benutzt worden, die entsprechenden Kategorienamen. Diese können zwar ausgewählt werden, können aber keinem Befehl zugeordnet werden. |
Start/Stop | Der Befehl Start/Stop startet und stopt den ausgewählten Effekt für automatischen Ablauf. (Der Befehl sollte im Zusammenhang mit dem T-Flag eingesetzt werden.). |
| Start | Der Befehl Start startet den ausgewählten Effekt im Effektsequencer für automatischen Ablauf. | ||
| Stop | Der Befehl Stop stopt den ausgewählten Effekt im Effektsequencer für automatischen Ablauf. | ||
| Beschl. setzen | Mit diesem Befehl läßt sich die Effektbeschleunigung auf den in Wert eingegebenen Prozentwert setzen. | ||
| Intes. setzen | Mit diesem Befehl läßt sich die EffektIntensität auf den in Wert eingegebenen Prozentwert setzen. | ||
| Nächster Schritt | Führt bei Effekten, die auf Wiedergabemodus Nur ein Schritt eingestellt sind, den nächsten Schritt aus. | ||
| Wiederh. Ein/Aus | Schaltet die Option Wiederholen für den gewählten Effekt Ein/Aus. (T-Flag benutzen) siehe Hinweis | ||
| Musikgest. Ein/Aus | Schaltet die Option Musiksteuerung für den gewählten Effekt Ein/Aus. (T-Flag benutzen) siehe Hinweis | ||
| Nächst. Wiedergabemodus | Wählt den nächsten Wiedergabemodus für den gewählten Effekt aus. | ||
| Wiedergabemodus: * Manuell * Normal * Rückwärts * Hin und her * Zufällig * Nur ein Schritt |
Wählt den entsprechenden Wiedergabemodus für den gewählten Effekt aus. | ||
| Intens. mit Start/Stop | Der Befehl Intens. mit Start/Stop startet und stopt den ausgewählten Effekt für automatischen Ablauf, gleichzeitig kann über die Wertspalte ein Prozentwert für die Helligkeit mit übergeben werden. |
Template unused
Geräte
Für das ausgewählte Gerät kann der entsprechende Kanal ausgewählt werden und ein entsprechender Wert imn der Spalte Wert zugewiesen werden. |
Bei Scannern und Movingheads besteht hier die Möglichkeit per Befehl die Achsen zu invertieren. | ||
| Sonstige Einträge | Unterhalb von Ausgewähltes Gerät befinden sich alle Geräte die dem aktuellen Projekt hinzugefügt wurden. Hier kann man dierekt ein Gerät auswählen auf, dass die weiteren Parameter angewendet werden. | Selektieren | Das entsprechende Gerät wird in der grafischen Bühnenansicht ausgewählt. |
| Sonstige Kanalbezeichungen | Für das ausgewählte Gerät kann der entsprechende Kanal ausgewählt werden. Hierbei werden hier die im DDF angegebenen Namen der Kanäle angezeigt. | ||
Gruppenauswahl
Joystick
| Steuerung | Auf die Joysticksteuerung wird der nächste Befehl (Kanal) angewendet. | Ein/Aus | Die Joysticksteuerung wird Ein-bzw. Ausgeschaltet (T-Flag). |
| Aktivieren | Die Joysticksteuerung wird aktiviert. | ||
| Deaktivieren | Die Joysticksteuerung wird deaktiviert. |
Kommandobox
| Bank | Bei Auswahl dieser Funktion, besteht die Möglichkeit über den Befehl auf die verschiedenen Banken (1-10),in der Kommandobox, zuzugreifen. | Nächste | Wählt die nächste Bank aus. |
| Bank 1 bis 10 | Direkte Auswahl einer der zehn Banken. | ||
| Button | Mit der Funktion Button lassen sich schon erstellte Befehle in der Kommandobox klonen oder in anderen Modulen nutzen. | Button-Name | Name des Buttons der benutzt werden soll. |
Kommandozeile
| 0-9,.,+,-,Thru @,Full,Enter, Del,/,Slider |
Auf die einzelnen Bedienelemente der Kommandozeile incl. des Sliders wird der nachfolgende Befehl angewendet. | setzen | Wählt das entsprechende Bedienelement aus, bzw. setzt den Slider auf einen Wert. |
Master
| Grandmaster | Der weitere Parameter wird auf den Grandmaster angewendet. | setzen | Der Wert wird auf den Grandmaster angewendet. (Submaster, Midi, DMXIn oder der angegebene Prozentwert zum O-Flag) |
| Sek. Grandmaster | Der weitere Parameter wird auf den Sekundären Grandmaster angewendet. | setzen | Der Wert wird auf den Sekundären Grandmaster angewendet. (Submaster, Midi, DMXIn oder der angegebene Prozentwert zum O-Flag) |
| Speedmaster | Der weitere Parameter wird auf den Speedmaster angewendet. | setzen | Der Wert wird auf den GSpeedmaster angewendet. (Submaster, Midi, DMXIn oder der angegebene Prozentwert zum O-Flag) |
| Flashmaster | Der weitere Parameter wird auf den Flashmaster angewendet. | setzen | Der Wert wird auf den Flashmaster angewendet. (Submaster, Midi, DMXIn oder der angegebene Prozentwert zum O-Flag) |
MIdi-Remote
| Bank | Bei Auswahl dieser Funktion, besteht die Möglichkeit über den Befehl auf die verschiedenen Bänke,in der Midi-Fernsteuerung, zuzugreifen. | Nächste | Wählt die nächste Bank aus. |
Soundanalyser
| Sound2Light | Die weiteren Befehle (Kanal) werden nur auf die Sound2Light Funktion angewendet. | Ein/Aus | Unter Benutzung des T-Flags kann die Funktion ein- und ausgeschaltet werden. |
| Aktivieren | Mit dem Befehl wird die Sound2Light Funktion aktiviert. | ||
| Deaktivieren | Mit dem Befehl wird die Sound2Light Funktion deaktiviert. | ||
| Bank | Mit der Funktion Bank kann die Entsprechende Bank aus dem Dropdown im Sound Analyzer ausgewählt werden. | Bankname | Unter Kanal stehen die entsprechend angelegten Banknamen aus dem Dropdown im Sound Analyzer. |
Submaster
| Wert setzen | Der ausgewählte Kanal wird auf den entsprechenden Wert in der Spalte Wert gesetzt. (O-Flag muss gesetzt sein) |
1-12 | Entspricht dem Subbmaster 1-12 in der ausgewählten Bank. Der Befehl wird auf den entprechenden Submaster angewendet. |
| Bankname: 1-12 | Entspricht dem Subbmaster 1-12 in der Bank mit Bankname. Der Befehl wird auf den entprechenden Submaster angewendet. | ||
| Flashen | Mit diesem Befehl können alle osder der gewählte Kanal per Befehl geflasht werden. | Alle | Der Befehl wird auf alle 12 Submaster angewendet. |
| 1-12 Bankname: 1-12 |
Der Befehl wird auf den ausgewählten Submaster angewendet. (siehe auch oben) | ||
| Wert erhöhen Wert verringern |
Der ausgewählte Kanal wird um den Wert 5 erhöht bzw. erniedrigt. | 1-12 Bankname: 1-12 |
siehe oben |
| Bank auswählen | Mit dem Befehl kann eine der ertsellten Banken im Submaster ausgewählt werden. | Banknamen | HIer kann der entsprechende Bankname ausgewählt werden, der dann ausgewählt wird. |
Szenenbibliothek
| Alle Einträge | Die Einträge im Dropdown Gerät/Funktion, sind alle Szenen innerhalb der Szenenbibliothek. Bei Auswahl eines Eintrags kann der Befehl im Dropdown Kanal auf die Szene angewendet werden. | Ausführen | Führt die gewählte Szene direkt aus. |
| Einblenden | Führt die gewählte Szene, mit der in der Szene abgespeicherten Einblendzeit, aus. |
Szenenliste
| Ausgewählte | Der weitere Befehl wird auf die aktuell ausgewählte Szeneliste angewendet. (Der Befehl Auswählen macht bei dieser Funktion keinen Sinn) |
Start/Stop | Der Befehl Start/Stop startet und stopt die ausgewählte Szenenliste für automatischen Ablauf. (Der Befehl sollte im Zusammenhang mit dem T-Flag eingesetzt werden.) |
| Start | Der Befehl Start startet die ausgewählte Szenenliste für automatischen Ablauf. | ||
| Stop | Der Befehl Stop stopt die ausgewählte Szenenliste bei automatischen Ablauf. | ||
| G O ! | Der Befehl G O ! führt die nächste Szene aus der Szeneliste aus. | ||
| Zu akt. Szene scrollen | Der Befehl Zu akt. Szene scrollen scrollt die aktuelle Szene in den sichtbaren Fensterbereich. | ||
Der weitere Befehl wird auf die aktuell nächste, vorherige oder im Dropdown benannte Szeneliste angewendet. | Auswählen | Wählt die nächste, vorherige bzw. die im Dropdown Gerät/Funktion benannte Szenenliste aus. |
| Start/Stop Start Stop G O ! Zu akt. Szene scrollen |
siehe oben |
Textbuch
| Go-Button | Auf den Go-Button wird der weitere Befehl angewendet. | Auswählen | Der Button wird bei Ausführen des Befehls betätigt. |
| Zurück-Button | Auf den Zurück-Button wird der weitere Befehl angewendet. | Auswählen | Der Button wird bei Ausführen des Befehls betätigt. |
| Vor-Button | Auf den Vor-Button wird der weitere Befehl angewendet. | Auswählen | Der Button wird bei Ausführen des Befehls betätigt. |
| Textbuch auswählen | Der weitere Befehl wählt das entsprechende Textbuch aus. | Nächstes | Wählt das nächste Textbuch aus. |
| Vorheriges | Wählt das vorherige Textbuch aus. | ||
| Textbuch-Name | Wählt das Textbuch mit dem Namen aus der Dropdown-Liste. |
