| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 21:03, 15 November 2013 (UTC) 4700 days ago. |
Hint:
25.5.2013: UPrenner: create the article page
| Inhaltsverzeichnis A B C D E F G H I J K L M N O P Q R S T U V W X Y Z Ü |
ArtNet
ArtNet (or Art-Net) is an IP based protocol for the assignment of large quantities of DMX information about LANs or WANs under use of the default network topology. The present ArtNet uses UDP about IP. The specification was made by the company "Artistic Licence" and is freely available in version 3 at the moment (Download). She was appreciated by bigger manufacturers.[1][2][3] The advantage of ArtNet consists that the DMX cables are replaced by Ethernetkabel in parts of the transmission path. One needs no more classic DMX transmitter at the PC with that since the signals are sent about a mostly per default available network interface. A complete show can theoretically be steered over the Internet with that. WLAN ways are more practice relevant so that the wiring can be dropped on unfavorable ways or even for the most part. Another advantage is the bi direktionale communication for re-registrations by means of RDM which, however, isn't supported of DMXControl yet. Also proprietary protocols are conceivable since the UPD protocol bi direktional is interpreted. Since the steered equipment has DMX interfaces for the most part by means of 5-pole XLR sockets furthermore, one needs another one or several so-called ArtNet knots which one, the ArtNet information in standard DMX 512 signals zurückverwandeln. So an ArtNet knot gets the signals about a network interface for one and or more DMX university verses distributes the DMX signals separated according to university verses about XLR. These Nodes even can be built themselves: Art-Net-Node für 25 Euro.
Audio cue
Audio cues permit playing an audio file in a definable length. You are usable for cues in various tools equally. The light technician also can synchronously steer audio sequences to the light with that. E.g. there is an important application for this at the theater control by means of script.
| Figure 1: Create a audio cue |
To other cues an audio cue analogously gets an eloquent name so that these are re-traceable also in the cue library. As a wave file WAVE, MP3, MP2, MP1 and OGG-Vorbis files can be used. Like other cues also can the audio cue a duration be assigned to control the temporal sequence of the cues and with that the length of the wave file as of the beginning. Has suitably to be broken off around the audio input after the adjusted time the option "after passed duration stop account". The duration also can on be limited manually to carry out the control over the "GO" button. Audio cues can be assigned to one by 16 (audio-)channels. About the channel number audio cues can be broken off by command. Siehe auch Audio manager
Audio manager
The audio manager as a drop down menu hides behind the "audio stop" button or courage button in the control center (loudspeaker with a red point). An overview has active audio streams (channels) opened out for itself there. The left symbol says to the statuses of the respective audio scene the audio stream can be manipulated with the respectively right symbol group with the usual functions break, rewinding, stop. The channels can be changed in the volume one by one and switched dumbly about orders. Several audio cues also can be on a channel.
| Figure 2: View of the audio manager in the control center |
Output plugins
The union on the side of the software which processes the generated DMX data represents a version Plugin between DMXControl and a hard or software. This mainly is DMX interfaces (transmitters) which pass the data (mostly cable-bound) on to a DMX-capable device. The union to a visualisierer or by ArtNet is but also taken by output plugins. See also Output plugins.
Termination resistor
To ensure of a loss and trouble-free assignment of the DMX signals the DMX512 protocol requires RS485 standard a terminating resistor of 120 Ohm at the end of the DMX chain between the signal leads (exact this). Feedbacks and signal reflections which could distort further sent values are prevented with that. €Zhowever, one gets her aurochs guarantee of a loss and trouble-free also by the installation of a corresponding resistance into a DMX plug between datas+ and data ), (Pin 1 and 2) produce themselves.
Bank
Innerhalb bestimmter Module können Bänke angelegt werden, die zur Bereithaltung verschiedener Einstellungen des gleichen Moduls dienen. Mittels Befehlen kann zwischen den Bänken gewechselt werden. In folgenden Modulen können Bänke erstellt werden:
- DMX-IN Fernsteurerung
- Zuweisung von DMX-IN-Kanälen
- Kommandobox (Seiten)
- Auswahl verschiedner Seiten (maximal 10)
- Midi Fernsteuerung
- Zuwesisung von MIDI-Kanälen
- Sound Analyzer
- Zuweisung der Spektrums-Balken
- Submaster
- Zuweisung der 12 Submaster. Dadurch ist es möglich, Gruppen von Geräten logisch anzuordnen, beispielsweise Bänke für "Front PARs", "Audience", "Saallicht".
Befehl
siehe Befehlsübersicht DMXC2
Blackout
Ein Blackout beschreibt in der Lichttechnik das sofortige Ausschalten (bzw. Verdunkeln) aller Lichtquellen. Übertragen auf das DMX-Protokoll bedeutet das, dass alle Dimmerkanäle sofort auf 0% gesetzt werden. In DMXControl befindet sich ein "Blackout"-Button im Steuerzentrum. Wird dieser aktiviert, werden alle als Dimmerkanäle definierten Kanäle auf 0% gesetzt und die Ausgabe auf diesen Kanälen gesperrt, bis der Blackout wieder aufgehoben wird.
DDF
DDF ist die Abkürzung für "Device Definition File". DDFs werden von DMXControl verwendet, um Informationen über die verwendeten Geräte im XML-Format zu beschreiben. In einem DDF sind unter anderem die Kanalbelegung des Gerätes, das Layout des Steuerungsfensters sowie weitere Informationen enthalten. Die DDFs befinden sich im Unterordner "Devices" des DMXControl-Programmverzeichnisses. Die zugehörigen Gerätebilddateien, welche in der Grafischen Bühnenansicht angezeigt werden, liegen in einem weiteren Unterordner namens „Images“. Ein DDF-Bibliothek wird standardmäßig installiert. Zur Erstellung eigner DDFs siehe DDF DMXC2.
DMX512
Das DMX512 Protokoll (kurz DMX) wurde 1886 von der USITT, einer amerikanischen Organisation definiert, die sich u.a. mit Theater-Technik beschäftigt. Mit diversen Verbesserungen ist es auch seit 1994 in Deutschland standardisiert (DIN 56930 /Teil2). DMX steht für DigitalMultipleX, was bedeutet, dass die Signale zu den Dimmern und anderen Geräten digital über eine Leitung übertragen werden. Im Gegensatz dazu hatten die früheren Systeme jeweils eine analoge Leitung zu jedem einzelnen Gerät. Da die Geräte bei DMX hintereinander geschaltet sind, spricht man auch von einer DMX-Kette (engl. daisychain). Jedes angeschlossenes Gerät in einem Universe hat eine eindeutige Startadresse zwischen 1 und 512. An einem DMX-Strang sollten aber nur maximal 32 Geräte angeschlossen werden, da sonst die Last auf der Leitung zu groß wird. Dann kann mit Verstärkern oder Splittern Abhilfe geschaffen werden. Über das DMX Protokoll kann in einem Zyklus auf jedem Kanal ein Wert zwischen 0 und 255 gesendet weden. Die Bedeutung des Wertes ist nicht im DMX Protokoll definiert, sondern hängt individuell vom Gerät ab. Für DMX sollen abgeschirmte Zweidraht-Leitungen mit 5-poligen XLR-Steckern verwendet werden. In der Praxis findet man aber insbesondere bei günstigen Geräten 3-polige XLR-Verbinder vor - diese sind dann aber nicht normgerecht und dürfen nicht die Bezeichnung DMX512 tragen. Template:BoxReferenz
DMXC Plugin
DMXControl definiert zwei Arten von Plugins zur Erweiterung der Funktionalität:
- Ausgabeplugins zur Unterstützung verschiedener neuer DMX Interfaces
- Anwendungsplugins zum Einfügen neuer Tools und Funktionen in DMXControl
DMX Interface
Ein "DMX Interface" (häufig auch "DMX Transmitter" oder "DMX-Sender" genannt) stellt das Hardware-Interface zwischen PC und dem DMX-Universum dar. Es gibt die von DMXControl erzeugten Werte auf die DMX-Kette. Die Transmitter können intern, seriell, parallel oder über USB am PC angeschlossen sein. Für den produktiven Einsatz von DMXControl bzw. die reale Ansteuerung von DMX-fähigen Geräten benötigt man ein DMX Interface, prinzipiell funktioniert das Programm (vor allem zu Übungszwecken) auch ohne Interface vollständig. DMXControl verwendet Ausgabeplugins, um verschiedene DMX-Sender mit einer einheitlichen Schnittstelle anzusprechen. Auf unserer Homepage findet sich eine komplette Liste der von DMXControl unterstützten DMX Interfaces. Die DMXControl-seitige Interface-Spezifikation ist verfügbar, so dass Sie selbst ein Ausgabeplugin erstellen können. Beim Programmstart sucht DMXControl in seinem Programmverzeichnis nach Dateien mit der Endung ".out.dll", welche die Ausgabeplugins repräsentieren. Über den Menüpunkt Ausgabeplugins kann man dann die benötigten Plugins aktivieren und konfigurieren.
Dimmerkanal
Kanäle, welche als Dimmer fungieren, werden im DDF des jeweiligen Gerätes mittels type=dimmer“ als solche definiert. Anhand dieser Information kann DMXControl bestimmte Funktionen nur auf Kanäle anwenden, die auch die Helligkeit eines Gerätes steuern. Dies sind unter anderem:
- Grandmaster
- Blackout
- Automatisches HTP
- Balken unterhalb des Geräte-Icons in der Grafischen Bühnenansicht
Einblendzeit
Um sanfte Übergange zwischen Szenen zu realisieren, kann man in DMXControl eine Einblendzeit für jede Szene definieren. Während dieser Zeitspane werden die DMX-Werte kontinuierlich den gespeicherten Werten angenähert und schließlich auf diese gesetzt (engl. faden). Der Gegensatz dazu ist eine schlagartige Änderung der Werte bei einer Einblendzeit von 0 Sekunden. Bei Kanälen, welche nicht gefadet werden(z. B. Goboräder), kann ein Überblendpunkt definiert werden.
Fader
Ein Fader ist klassischerweise ein mechanischer Schieberegler, der einen elektrischen Widerstand ändert und findet sich beispielsweise an Audio- oder Lichtmischpulten. Das englische Verb to fade drückt einen fließenden, kontinuierlichen Übergang zwischen zwei Werten aus. Bekannt ist vor allem das Fadein und Fadeout als Laustärkeänderung am Beginn und Ende eines Musikstücks. (Software-)Fader finden in DMXControl hauptsächlich im Submaster Tool Verwendung. Sie dienen dazu, genaue DMX-Werte einzustellen oder sanfte Übergänge zwischen Szenen zu realisieren. Auch in vielen DDFs sind Fader definiert und ermöglichen dort unter anderem die Einstellung von Dreh- und Strobegeschwindigkeiten oder Farben.
Farbfilter
Ein Farbfilter ist ein Vorsatz für eine Lampe, der ihr Licht einfärben soll. Meist sind Farbfilter farbige Kunststofffolien. Daneben gibt es auch dichroitischen Filter, die aus Glas bestehen und eine deutlich bessere Filterung ermöglichen zu einem höheren Preis. [4]
Farbrad
Ein Farbrad findet sich oft in Movingheads und anderen Multifunktionsscheinwerfern. Es ist eine Scheibe, auf welcher Glasfarbfilter kreisförmig angeordnet sind und in den Strahlengang reichen. Durch das Farbrad können in verschiedenen diskrete Lichtfarben oder Halbfarben erzeugt werden.
Flashbutton
Flashbuttons setzen die ihnen zugewiesenen Kanäle kurzzeitig (für die Dauer der Betätigung) auf den zulässigen Maximalwert. Dieser wird in DMXControl durch die Maximalwerte im DDF und den Flashmaster festgelegt.
Gerät
In DMXControl bezeichnet der Begriff Gerät einen Punkt in der DMX-Signalkette, an dem das Signal ausgewertet wird. Dies kann beispielsweise geschehen durch
- einen Dimmer
- eine Nebelmaschine
- einen Multifunktionsscheinwerfer wie Movinghead oder Scanner
- ein Anwendungsplugin
- ein Flammenwerfer :)
- alles, was DMX verarbeiten kann
Ein Gerät ist meist (aber nicht zwingend) auch physikalisch vorhanden und reagiert auf die gesendeten DMX-Signale. Geräte werden durch DDFs beschrieben, diese enthalten alle nötigen Informationen zur Ansteuerung. In der Grafischen Bühnenansicht können Geräte angelegt, gelöscht und vor dem Hintergrundbild verschoben werden. Ein Klick auf das Geräteicon öffnet das Steuerungsfenster. Geräte benötigen immer eine Startadresse.
Gobo / Goborad
Ein Gobo (Graphical optical blackout) verändert den Lichtstrahl eines Scheinwerfers. Es ist eine Maske, aus der geometrische Formen, Texte oder Bilder herausgeschnitten sein können. Der Lichtstrahl nimmt dann diese Form an. Gobos gibt es in Metallausführung aus dünnen Blech gestanzt oder als teurere Glasgobos in Kombination mit dichroitischen Filtern. In den Scheinwerfern selbst sitzen oftmals mehrere Gobos kreisförmig auf einem Goborad. Je nach Drehung des Goborades, befindet sich ein bestimmtes Gobo im Lichtstrahl, wobei der Strahl dann dessen Motiv annimmt. Auch gibt es die Möglichkeit, Gobos um sich selbst rotieren zu lassen.
HTP
HTP steht für "highest takes precedence" (der höchste Wert setzt sich durch) und wird üblicherweise für Dimmerkanäle benutzt, um z.B. ein Flackern durch parallele Änderungen aus mehreren Quellen zu verhindern. DMXControl kann HTP auf alle Kanäle anwenden, die als "Dimmer" gekennzeichnet sind. Somit wird immer der höchste Wert auf einem Kanal ausgegeben, so dass man z.B. den Sound Analyzer laufen lassen und gleichzeitig einen Effekt darüberlegen kann. Möglich wäre damit auch eine Lampenvorheizung, denn der Wert "10" würde sich gegenüber der "0" z.B. von einem laufenden Effekt durchsetzen. Standardmäßig ist der HTP-Modus deaktiviert, kann aber in der Programmkonfiguration einfach eingeschaltet werden. HTP/LTP wird pro Kanal verarbeitet - Kanäle die im DDF als "type=dimmer" eingetragen sind werden HTP gemischt, der Rest LTP. Wenn man in der Programmkonfiguration HTP aber komplett abschaltet, dann werden auch Dimmerkanäle LTP-gemischt. Wenn Sie Probleme mit "hängenden" Kanälen haben, hat das vermutlich mit dem HTP-Modus zu tun. In der Kanalübersicht wird angezeigt, welcher Kanal von welchem Mixerkanal zuletzt verändert wurde. Wird z.B. ein Kanal von einer Szene voll aufgezogen, kann er nur von der nächsten Szene oder durch Schließen des Szenentools wieder auf einen niedrigeren Wert gesetzt werden. Wenn eine Szene in eine andere überblendet, sollten sich die alten Werte auch reduzieren lassen.
Lampenvorheizung
Die Lampenvorheizung (auch Pre Heat) dient dazu, die Lebensdauer Ihrer Leuchtmittel zu erhöhen. Dabei werden die Lampen nicht ganz ausgeschaltet, sondern immer leicht gedimmt betrieben, sodass die Lampe gerade noch nicht sichtbar ist. In DMXControl lässt sich eine Lampenvorheizung erreichen, indem Sie
- den HTP-Modus aktivieren (in der Programmkonfiguration),
- eine Szene speichern, die die gewünschten Kanalwerte für die Vorheizung enthält und
- diese Szene über einen Befehl beim Programmstart aufrufen lassen (auch Programmkonfiguration).
LTP
LTP steht für "latest takes precedence" (der letzte Wert setzt sich durch) und wird bei DMXControl automatisch für alle Kanäle benutzt, die nicht als "Dimmer" gekennzeichnet sind. Dabei wird die letzte Kanaländerung direkt an das Ausgabesystem weitergereicht. Wird der Mixerkanal geschlossen, wird auf jedem DMX-Kanal der Zustand vor der ersten Änderung durch den gerade geschlossenen Mixerkanal wiederhergestellt.
Leitungsterminierung
Zur Gewährleistung einer verlust- und störungsfreien Übertragung des DMX-Signals verlangt das DMX512 Protokoll einen Abschlusswiderstand von 120 Ohm am Ende der DMX-Kette zwischen Data+ und Data- (Pin 2 und 3). Damit werden Rückkopplungen und Signalreflexionen verhindert, die weitere gesendete Werte verfälschen könnten. Es gibt kommerzielle Abschlussstecker zu kaufen (5-7€), man kann sich aber auch durch den Einbau eines entsprechenden Widerstandes in einen DMX-Stecker ein solches Gerät selbst herstellen.
Master
Ein Master ist die letzte Instanz, die Einfluss auf das Signal nimmt, bevor es zur Ausgabe gelangt. Änderungen an einem Master Controller wirken sich synchron auf alle untergeordneten Kanäle aus bzw. geben Maximalwerte für sie vor. In DMXControl gibt es das Modul Master, in dem sich Grandmaster (Dimmer), Sekundärmaster (Dimmer), Flashmaster (Maximalwert für Flashbutton) und Speedmaster (Geschwindigkeit von Effekten und Einblendzeiten) befinden.
Mixerkanal
DMXControl verwendet intern einen Mixer, der die DMX-Ausgaben der verschiedenen aktiven Tools sammelt und daraus die Ausgabewerte generiert, die dann auf dem jeweiligen DMX-Sender ausgegeben werden. Die unterschiedlichen Quellen (also meist Tools) werden dabei als "Mixerkanäle" bezeichnet, nicht zu verwechseln mit DMX-Kanälen. Ein Mixerkanal umfasst normalerweise den gesamten DMX-Kanalraum, den die jeweilige DMXControl-Version zur Verfügung stellt (256 bzw. 512 Kanäle). Wird ein Mixerkanal „geschlossen“, werden auch die Ausgabewerte neu berechnet. Im Mixersystem von DMXControl behält immer das Tool, das vom User als letztes bedient wurde die Controlle, bis
- das Tool geschlossen wird,
- ein anderes Tool bedient wird
- das Tool zurückgesetzt wird.
Manche Tools wie der Audioplayer z.B. bieten eine Taste, mit der man das Tool rücksetzen kann (kleiner roter durchgestrichener Kreis). Beispiel: Wenn man mit der Flash Taste des Submasters einen Kanal bedient, ist der Submaster das letzte Tool, was auf den Kanal zugreift. Damit ein anderer Effekt auf diesem DMX-Kanal wieder wirkt, kann man 3 Dinge tun:
- Das Submaster Fenster schließen,
- den Effekt neu starten und
- den Submaster zurücksetzen.
Mixermodus
Ein Kanal des internen Mixers kann nach 2 Vorgaben gemischt werden, diese sind LTP und HTP.
Projekt
Sie können verschiedene Projekte (Shows) generieren, speichern und (jeweils zu einem Zeitpunkt genau ein Projekt) laden. In DMXControl enthält ein Projekt alle Projektdaten, die für eine Show relevant sind. Solche Daten sind unter anderem welche DMX-Geräte verwendet werden, erstellte Szenen und Effekte, Ein- und Ausgabekonfigurationen und einiges mehr. Sie werden von den einzelnen Modulen von DMXC in einem gemeinsamen Ordner aber mit unterschiedlichen Dateiendungen gespeichert.
Darüber hinaus gibt es auch sog. globale Daten, die DMXControl projektübergreifend in einem separaten Verzeichnis ("%Appdata%/PopSoft/") speichert. Zu diesen globalen Daten gehören auch Einstellungen der MIDI- und DMX-Fernsteuerungen. Daher müssen diese Daten beim Kopieren eines Projektes auf einen anderen Computer auch mitkopiert werden. Wie das am einfachsten funktioniert, kann in Kapitel 31 nachgelesen werden.
Spektrum
Startadresse
Jedes physikalische Gerät in einer DMX-Signalkette besitzt eine sogenannte Start- oder Basisadresse. Diese wird am Gerät selbst eingestellt, idealerweise ist sie identisch mit der Startardresse des Gerätes in DMXControl. Diese Adresse bezeichnet den niedrigsten, aber nicht zwingend den einzigen, Kanal, ab dem ein Gerät die DMX-Werte verarbeitet. Ein 4-kanaliger Dimmer mit der Startadresse 5 wertet die Kanäle 5,6,7 und 8 aus, ein Movinghead kann für seine Funktionen durchaus 15 oder mehr Kanäle belegen. Es ist auch möglich, mehreren Geräten die gleiche Startadresse zuzuweisen. Dies kann zu ungewollten Resultaten führen, jedoch auch bei gleichen Scheinwerfern bewusst eingesetzt werden für synchrone Ausgaben. Wie die Startadresse eingestellt wird, hänge vom Gerät ab, beachten Sie hierbei bitte die Bedienungsanleitung des Herstellers. Template unused
Submaster
Ein Submaster ist ein Fader, der Werte von verschiedenen Kanälen gemeinsam steuern kann. Das Submaster-Konzept wird in DMXControl durch das Submaster Tool realisiert, wobei jeder Submaster aus einem Fader und einem Flashbutton besteht. Mittels eines Submasters können zum Beispiel gleiche Funktionen gebündelt werden, also alle Rot-Kanäle von 10 LED-Scheinwerfern.
Szene
Eine Show besteht aus diversen Szenen. Eine Szene ist eine momentane Einstellung aller angeschlossenen Geräte (DMX-Werte). Pro Szene kann eine Einblendzeit sowie eine Haltezeit angegeben werden, welche jedoch nur innerhalb der Szenenliste oder eines Effektes zum Tragen kommt. Werte einer Szene bleiben auf der Ausgabe aktiv, bis sie explizit überschrieben werden, beispielsweise durch eine andere Szene. Template:Bild mit Unterschrift Neben der „Einfachen Szene“ können Befehle, Bewegungs- oder Audioszenen verwendet werden. Alle Szenen werden in der Szenenbibliothek verwaltet und können von dort gewählt und wiederverwendet werden. Kompositionsszenen können beliebige Szenentypen zusammenfassen. Template unused
Szenenliste
Ü
Überblendpunkt
Der „Einsatzpunkt“ wird beim Überblenden zwischen zwei Lichtstimmungen verwendet. Während als Kanäle mit dem Attribut "fade=yes" (Dimmer) weich übergeblendet werden, müssen die übrigen Kanäle (Shutter, Goborad) an einer Stelle abrupt auf den neuen Wert gesetzt werden. Der Einsetzpunkt stellt die Stelle auf der Zeitleiste (zwischen 0 und 100% der Überblendung) dar, an der das Umschalten passiert. Auf diese Weise können Gobos entweder am Anfang oder am Ende der Einblendzeit gewechselt werden.
Referenzen
- ↑ Martin Ether2DMX8™. Abgerufen am 12. März 2013.
- ↑ JB Lightning Licon 2X. Abgerufen am 12. März 2013.
- ↑ Einbindung in die Open Lighting Architecture. Abgerufen am 12. März 2013.
- ↑ http://eshop.steinigke.de/out/pictures/wysiwigpro/cmscontent/support/whitepaper/de/licht/Filtercaf%C3%A9%20%E2%80%93%20Was%20ist%20ein%20dichroitischer%20Filter.pdf
