| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 12:56, 9 November 2013 (UTC) 4606 days ago. |
Hint:
07.11.2013 UPrenner: work-in-progress
| Figure 1: Grafische Bühnenansicht mit DDF-Icon |
| Figure 2: Geöffnetes DDF-Fenster mit Steuerelementen |
DDF is the abbreviation of Device Definition File. The DDF are the device description (Fixtures) in DMXControl, they serve to inform DMXControl about the functions of the attached DMX device to this. In the DDF the number becomes this one how channels of the DMX device defined and as well these use possible control elements:
- Position input control element e.g. at Movingheads and Scanners.
- RGB or CMY color choice control element to the color mixture at e.g. LED headlight or color mixed units at Movingheads.
- Dropdown control elements
- Button control elements.
Become the DDF in the « graphical view » with an icon of the device shown (see figure 1), then also can here be accessed the icon, the DDF window by a click with the control elements (see figure 2). XML format which is translated by DMXControl into the internal device description is carried out the description the DMX equipment in one. The DDF are found the DMXControl main directory in the sub-folder DEVICEs. The accompanying icon pictures, which one in the & laquo; Graphic stage view & raquo; be, lie in another sub-folder named shown images.
You get prefabricated DDFs, which weren't enclosed at the installation, can you perhaps of the DMXControl home page in the device library[1]. DDF can be made in a simple way with a XML editor (e. g. PSPad[2]) or also with the DDFCreator. There are advantages and disadvantages with the DDFCreator as also the construction of a DDF with a XML editor. With a XML editor, paraphrasing an existing DDF can be managed considerably faster than with the DDFCreator, against this one is fundamentally faster with the DDFCreator at the construction of a new DDF surface with slidern, button etc.
At both one needs a corresponding knowledge to make an operating DDF no matter whether one now the DDFCreator preferred or the XML editor. Shall the following chapters be conveyed for you, this knowledge among other things the language reference serves as a reference book
Description
A very common language syntax which e.g. is also used in the other dialects at web pages or WAP in the Internet sides is XML (eXtensible Markup Language). But you don't have to be an expert to make a new device description too manually. The following simple notes suffice:
Please take care that your editor doesn't store any (invisible) control characters. There won't be any problems at the Windows editor or PSPad. If you want to use Word or similar software, you should save the file in the raw document format (*.txt).
- The DMXControl dialect of XML requires for every opening tag always one (<tag>) closing (</tag>) tag. Only this one gets the last level completed just by implication day (e. g. <item caption= "white" value="0" />).
- The final signs /> and </tag> are semantically equivalent, also <item caption="white" value="0" > </item> is valid in this case.
- Every day can have attributes which you find professed in the table below. Every attribute value is started with an equals sign and the value must always be included in double apostrophes.
- All day and attribute identifiers are noted down at DMXControl in a small letter.
- The day has to be defined hierarchically. They also should make this recognizable about corresponding indents.
- As a rule, not cares about the order of the attributes of a day. Where it for once depends on the order anyway, you describe below explicitly.
- Comment are noted down in the form <!- This is a comment —>.
- E.g. you can have a look at xml files (therefore also the DMX DEVICEs files) in open form with the Internet Explorer.
So it was already this - we have a look at a simple example.
Example: dimmed spotlight
Every device should get an apt icon to receive an adapted representation in stage representation. This icon will be find in the subdirectory Images (Root:\Programme\DMXControl\Devices\Images).
Template unused
The preceding line numbers of the following XML example file cannot be inserted; they serve only the description of the example:
3 <channels>
4 <function channel="0" minvalue="0" maxvalue="255" name="Intensity" fade="yes" />
5 </channels>
11 </form>
12 </device>
| Row 1 | the Parser will informed about the used XML version. | |
| Row 2 | the global description of the new type of device defines inclusive reference to the icon to be put and one ( initialization of the device the optional initsequence was demonstrated here, is but at a headlight only conditionally appropriately. The dimmer channel is (50%) ) put on DMX value 128 at the initialization here. | |
| Row 3 | the DMX channels of the device are defined between line 3 and 5. | |
| Row 4 | the channel description of the first channel is. This is always the channel numbers at zero important begin, i. e. the first channel is channel="0". In addition, other parameters as well as the channel name are still put here. | |
| Row 6 | the lines 6-9 describe the form, that is this one, to graphic coordinates in the context menu for the device picture, names and start address in the unity „Pixel“. | |
| Row 10 | here the operating devices follow a slider with his graphic coordinates and the assignment to the channel in question with her qualities, in this example now. Operating devices like radio badges also could, drop down or badges are declared for other types of device here. |
miniatur|200px|Bild 3: Dimmer-DDF
| Figure 3: Dimmer-DDF |
Three button become Pinup button, Move button, Close button will be generatedly per default generatedly on the top right side (see figure 3).
Create a DDF
Syntax overview
- Beschreibung globaler Eigenschaften device (im Beispiel Gedimmter Scheinwerfer Zeile 1-2)
- Beschreibung der einzelnen DMX-Kanäle channels (im Beispiel Gedimmter Scheinwerfer Zeile 3-5)
- Beschreibung des grafischen Kontextmenüs form (im Beispiel Gedimmter Scheinwerfer Zeile 6-11)
- Prozedurcode (optional, im Beispiel nicht enthalten)
| Figure 4: Grundsätzlicher DDF-Aufbau |
Graphical elements
| Figure 5: Grafische Elemente |
| Figure 6: Grafische Koordinaten der Steuerelemente |
Functional elements
| Konzept | Beschreibung | Beispiel | |
| 1 | Channel/Value concept | Über das channel-Attribut wird das Steuerelement einem konkreten Kanal zugeordnet. Im Steuer- element werden konkrete Werte oder Wertebereiche definiert, die bei der Betätigung des Steuer- elementes gesetzt werden. | - option Liste caption="Sternenhimmel" value="165" - Wertebereich des Schiebereglers startvalue="0" endvalue="255" |
| 2 | Sequences | Eine Anweisungsfolge wird im Steuerelement als String definiert, die beim Betätigen ausgeführt wird. | clicksequence= “set 1 75; set 2 100“ |
| 3 | Action/Procedures | Eine separat definierte Prozedur enthält komplexere Programm- anweisungen. Die Prozedur wird über das Action-Attribut zuge- ordnet und bei jedem Betätigen des Steuerelementes ausgeführt. | action="SetGobo" |
Template unused
| Figure 7: Interaction der Steuerelemente |
Template unused
Syntax
Generic attributs
Template unused
| Referenz | Attribut | Hierachie und Eigenschaft | Bemerkung | Beispiel |
| GP1 | value | Zugeordneter DMX-Wert | Byte | 0, 128, 255 |
| GP2 | caption | Beschreibender Aufzählungs- wert. Erklärender Name für eine Einstellung. |
| GP3 | top | Relative y-Koordinate des Elementes von der linken oberen Ecke |
integer | top=“150“ |
| GP4 | left | Relative x-Koordinate des Elementes von der linken oberen Ecke. |
integer | left=“100“ |
| GP5 | width | Breite des Elements | integer | width=“80“ |
| GP6 | height | Höhe des Elements | integer | height=“30“ |
Template unused
Device description
| Tag | Attribut | Hierachie und Eigenschaft | Bemerkung | Beispiel |
| <device> | Level 1 | |||
| image | Dateiname des Icons. | string, Filename.gif |
Moon.gif | |
| initsequence | Setzt Initialwerte für die einzelnen DMX-Kanäle des Gerätes |
Optionale Benutzung z.B. für Scanner/MH Startposition | set 0 15; set 7 128; | |
| <information> | Level 2 Ergänzender Kommentar. |
| <name> | Level 3 Beliebiger Text |
Custom Scanner | ||
| <vendor> | Level 3 Beliebiger Text (Hersteller) |
optional | Showtec | |
| <deviceidentifier> | Level 3 Beliebiger Text (Herstellerbezeichnung) |
optional | TG-3 | |
| <author> | Level 3 Beliebiger Text (Ersteller) |
optional | ||
| <comment> | Level 3 Beliebiger Text (Kommentar). |
optional | ||
| <help> | Level 2 Hilfetext (ASCII). |
optional |
Channel description
| <channels> | Level 2 Pro DMX-Kanal ist ein “<function>”-Teil zu definieren |
| <function> | Level 3 Subtag von “<channels>“ |
| channel | Interne DMX-Kanal-Nummer Kanalnr. müssen immer von 0 aufsteigend ohne Unterbrechung für die einzelnen Kanäle definiert werden |
integer | ||
| minvalue | Minimaler DMX Wert | integer | ||
| maxvalue | Maximaler DMX Wert | integer | ||
| name | Beschreibender Name für den Kanal |
string | Helligkeit | |
| fade | Kanal-Überblendung | string | yes,no | |
| type | Kanal-Typ Wichtig für die Interne Daten- verarbeitung |
| action | Aufruf einer Prozedur bei Änderung des Kanalwerts |
string optional |
| <virtual> | Level 3 Subtag von “<channels>“ |
| <channel> | Level 4 Subtag von “<virtual>“ |
| channel | Interne DMX-Kanal-Nummer Der drei dem virtuellen Dimmer zugeordneten Kanäle |
integer |
Template unused
| dimmer | reserviert für Kanäle die die Helligkeit regeln |
| r,g,b | reserviert für Kanäle von RGB LED-Geräten, r für den roten Kanal, g für den grünen Kanal, b für den blauen Kanal. Die type's r, g, b werden zum einen für die HAL in DMXControl benötigt. Das bedeutet, das in der grafischen Bühnenansicht auch die Farben der Scheinwerfer angezeigt werden. Eingestellen kann man dies in der Programmkonfiguration unter « Grafische Bühnenansicht » und dann bei « Symbole » « Darstellung der Farben statt Grafik verwenden ». Zum anderen werden die types auch für den in der 2.12 neuen LED Lauflichtgenerator benötigt. |
| a,w | reserviert für Kanäle von (RGB)A und (RGB)W LED-Geräten, a für den amber Kanal, w für den weißen Kanal. Die types a und w werden noch nicht von DMXControl unterstützt sind aber sinnvoll, da die Geräte mit zusätzlichen Amber oder Weiß Kanal einen immer größeren Anteil am Markt haben und deshalb eventuell auch bald von DMXControl unterstützt werden. |
| pan, panfine | reserviert für die Pan Kanäle von Scannern, Movingheads oder ähnlichen Geräten. Wobei pan dem Kanal für die Grobsteuerung zugeordnet wird und panfine dem Kanal für die Feinsteuerung, bei 16 Bit Geräten |
| tilt, tiltfine | wie bei pan und panfine aber für die Tiltachse |
| color, gobo | Können den entsprechenden Farb- und Goborad Kanälen zugeordnet werden (wichtig für Farb- & Gobolisten) |
| c, m, y | reserviert für Kanäle von CMY-Geräten, c für den Cyan Kanal, m für den magenta Kanal und y für den gelben Kanal. Die types c, m, y werden noch nicht von DMXControl unterstützt sind aber sinnvoll. |
| sonstige | alle anderen Kanäle benötigen keine Typbeschreibung |
Template unused
Menue description
| <form> | Level 2 Subtag von “<device>“ |
| width height |
Siehe Generische Attribute GP5; GP6 |
integer | ||
| <deviceimage> | 'Level 3 Subtag von “<form>“; Absolute Position des angezeigten Bildes |
| top left width height |
Siehe Generische Attribute GP3 bis GP6 |
integer | ||
| <devicename> | 'Level 3 Subtag von “<form>“; Absolute Position des angezeigten Namens |
integer | ||
| <deviceaddress> | 'Level 3 Subtag von “<form>“; Absolute Position des angezeigten Basisadresse |
integer |
Control elements
Position control
| Bild:DMXC2_Manual_DDF_Positionsfeld_kartesisch.png Bild:DMXC2_Manual_DDF_Positionsfeld_polar.png | ||||
| <position> | Level 3 Subtag von “<form>“; Erzeugt ein Positionierungs- feld zur Positionierung von Scannern oder Movingheads. |
Durch einen Klick auf den Button unten rechts im DDF kann zwischen kartesischer und polarer Positionierung umgeschaltet werden. | ||
integer | ||
Template unused
Slider
| Datei:DMXC2_Manual_DDF_Slider.png | ||||
| <slider> | Level 3 Subtag von “<form>“; Erzeugt einen Schieberegler |
integer | ||
| channel | Zugeordneter Kanal alternativ zu action |
integer optional |
| startvalue | Wertebereich des Schiebers (unterer Wert) |
integer | startvalue="0" | |
| endvalue | Wertebereich des Schiebers (oberer Wert) |
integer | endvalue="255" | |
| tickfreq | Skalierung, Abstand der Skalenunterteilung |
integer | tickfreq="32" | |
| smallchange | Änderungsrate z.B. beim Pfeiltastenscrollen |
integer (VB-Eigenschaft) |
smallchange="20" | |
| largechange | Änderungsrate z.B. beim Mausklicken (nicht ziehen) |
largechange="50" | |
| name | Referenzname für procedure code (Variablenname) |
string optional |
StrobeSpeed | |
| action | Aufruf einer Prozedur bei Änderung am Slider alternativ zu channel |
string optional |
SetSpeed | |
Dropdown
| Bild:DMXC2_Manual_DDF_Dropdown.png | ||||
| <dropdown> | Level 3 Subtag von “<form>“; Erzeugt ein Dropdown-Menü. |
| top left width |
Siehe Generische Attribute GP3 bis GP5 |
integer | ||
integer optional |
string optional |
Gobo | |
| action | Aufruf einer Prozedur bei Aufruf eines Dropdown- eintrags, alternativ zu channel |
string optional |
SetGobo | |
| <item> | Level 4 Subtag von “<dropdown>“ |
| caption | Erklärender Name | string | Clear | |
| value | DMX-Wert zu caption | integer | value="0" | |
| minvalue maxvalue |
Wertebereich zu caption zur Anzeige des Dropdown-Eintrags. |
integer | minvalue="10" maxvalue="26" | |
| color | Zeigt ein Quadrat mit der zuge- ordneten Farbe vor caption an |
hex | color="#ff0000" Farbe Rot | |
| <colorlist> | Level 4 Subtag von “<dropdown>“ Fügen alle Einträge der dem Gerät zugewiesenen Colorliste ein. |
optional Ersatz/ Ergänzung für Item |
| <gobolist> | Level 4 Subtag von “<dropdown>“ Fügen alle Einträge der dem Gerät zugewiesenen Goboliste ein. |
Options
| Datei:DMXC2_Manual_DDF_Options.png | ||||
| <options> | Level 3 Subtag von “<form>“; Erzeugt ein Radiobuttonfeld |
| top left |
Siehe Generische Attribute GP3 & GP4 |
integer | ||
integer optional |
| action | Aufruf einer Prozedur bei Auswahl eines Radiobuttons, alternativ zu channel |
optional | SetGoboSpeed | |
string optional |
GoboSpeed | |
| <option> | Level 4 Subtag von “<options>“ |
| caption | Siehe Generische Attribute GP2 |
string | off | |
| value | DMX-Wert zu caption | integer | 0 | |
| top left |
Siehe Generische Attribute GP3 & GP4, relative Position zur Position von “<options>“ |
integer | left="0" top="0" | |
On/Off-Button
| Bild:DMXC2_Manual_DDF_Onoff.png | ||||
| <onoff> | Level 3 Subtag von “<form>“; Erzeugt einen Button als Schalter |
integer | ||
integer optional |
| action | Aufruf einer Prozedur beim betätigen des Buttons alternativ zu channel |
string optional |
SetLampOnOff | |
string optional |
LampOnOff | |
| caption | Erklärender Name | string | An/Aus | |
| color | Hex RGB-Farbwert des Button | hex | color="#00ff00" Farbe Grün | |
| onvalue | DMX-Wert für Button ON | integer | onvalue="150" | |
| offvalue | DMX-Wert für Button OFF | integer | offvalue="0" | |
| onsequence | Sequence, die bei ON ausgeführt wird |
string | "set 0 230; set 1 25" | |
| offsequence | Sequence, die bei OFF ausgeführt wird |
string | "set 0 0; set 1 0" | |
Command-Button
| Datei:DMXC2_Manual_DDF_Command.png | ||||
| <command> | Level 3 Subtag von “<form>“; Erzeugt Button’s als Taster |
integer | ||
| action | Aufruf einer Prozedur beim betätigen des Buttons |
string optional |
SetReset | |
string optional |
Reset | |
| caption | Erklärender Name | string | Reset | |
| color | Hex RGB-Farbwert des Button | string | color="#0000ff" Farbe Blau | |
| clicksequence | Beim Buttonclick zu startende Aktivität ist im Attribut spezifiziert |
string | "save 0; set 0 230; hold 5500; restore 0" | |
| downsequence | Beim Niederdrücken zu startende Aktivität ist im Attribut spezifiziert |
| upsequence | Beim Loslassen zu startende Aktivität ist im Attribut spezifiziert |
Colorpicker
| Bild:DMXC2_Manual_DDF_Colorpicker.png | ||||
| <colorpicker> | Level 3 Subtag von “<form>“; Erzeugt einen Colorpicker. |
integer | ||
| channel1 | Zuordnung zum 1. Kanal Rot oder Cyan, alternativ zu action |
integer optional |
| channel2 | Zuordnung zum 2. Kanal Grün oder Magenta, alternativ zu action |
integer optional |
| channel3 | Zuordnung zum 3. Kanal Blau oder Yellow, alternativ zu action |
integer optional |
string optional |
ColRGB | |
| action | Aufruf einer Prozedur bei Änderung einer Farbe, alternativ zu channel1-3 |
string optional |
SetColRGB | |
| mode | Auswahl der zwei Modi RGB oder CMY |
string | mode=“cmy“ | |
| layout | Auswahl von zwei verschiedenen Layouts des Colorpickers |
integer | layout="1" | |
Beispiel:
Template unused
Passive design elements
| Bild:DMXC2_Manual_DDF_Line.png | ||||
| <line> | Level 3 Subtag von “<form>“; Gestaltungselement; Erzeugt eine Linie. |
| x1; y1 | Startkoordinate der Linie | integer | ||
| x2; y2 | Endkoordinate der Linie | integer | ||
| Bild:DMXC2_Manual_DDF_Label.png | ||||
| <label> | Level 3 Subtag von “<form>“; Gestaltungselement; zusätzliche Beschreibung eines Bedienelementes. |
integer | ||
| caption | Anzuzeigender Text | string | CMY Mischung | |
Beispiel: miniatur|zentriert|600px|Bild 8: DDF Giotto Spot 400
Help
miniatur|zentriert|600px|Bild 9: Hilfemenü eines DDF's
Sequences
| Operation | Bedeutung | Beispiel |
| save >channel< | Zwischenspeichern des aktuellen Kanal- werts des DMX-Kanals >channel< |
| set >channel< >value< | Setzt den Kanal >channel< auf Wert >value< |
| hold >time< | Timer (wartet >time< in msec.) | "save 0; set 0 230; hold 5500; restore 0" |
| restore >channel< | Setzt den zwischengespeicherten Wert des DMX-Kanals >channel< wieder zurück |
Procedurs (advanced programming options)
General principles
Basic syntax elements and conventions
| ! | beginnt einen Befehl |
| | | separiert die einzelnen Bestandteile |
| $ | beendet einen Befehl |
| + | Addition |
| - | Subtraktion |
| * | Multiplikation |
| / | Division |
| mod | Modulo-Operation (gibt den Rest der Mod-Division als Ergebnis aus) |
| DMXControl code | Generische Sprachvariante |
| !set_channel|2|(227+{color_speed})$ | channel_2 := 227 + color_speed |
| !set_channel|3|((({gobos_gobo}-1)*51)+25)$ | channel_3 := (gobos_gobo-1)*51+25 |
| !set_control|gobos_speed|((({channel_3}-1) mod 51)-26)$ | gobos_speed := ((channel_3 -1) mod 51)-26 |
| set_control | >cntr< | >val< | setzt das Steuerelement mit dem angegebenen Namen >cntr< auf den Wert des Ausdruckes >val< |
| set_channel | >ch< | >val< | Übergibt an den angegebenen Kanal >ch< den Wert >val< |
| Operation | Alternative Schreibweise | Bedeutung |
| > | > |gt| | größer |
| < | < |lt| | kleiner |
| = | &eq; |eq| | gleich |
| !if|{channel_3} < 1| | if channel_3 < 1 then |
Template unused
XML syntax of the procedure code
| <code> | Level 2 Subtag von "<device>" enthält alle Proceduren |
| <procedure> | Level 3 Subtag von "<code>" enthält den Code der Procedure |
| name | Name der Prozedur | string | SetGobo |
An example prozedure
Dieses Beispiel zeigt eine Prozedure, die die Werte der Steuerungselemente „color_color“ und „color_speed“ eines Movingheads in Abhängigkeit vom aktuellen DMX-Wert des Kanals 2 (Farbwechsler) setzt. Der Mac 250+ hat 4 Möglichkeiten für das Farbrad:
- Feste Farbe (erstes If im Beispiel unten),
- Drehung mit Uhrzeigersinn (2. If im Beispiel unten),
- Drehung gegen Uhrzeigersinn (3. If im Beispiel unten) sowie
- zufällige Farben mit unterschiedlicher Geschwindigkeit (4. If im Beispiel unten).
action="GetColor"/>
<procedure name='GetColor'>
Procedure GetColor( )
!if|{channel_2} < 208|
!set_control|color_color|
{channel_2}$
!set_control|color_speed|0$
!if|({channel_2} > 207) and
({channel_2} < 227)|
!set_control|color_color|-1$
(226-{channel_2})$
!if|({channel_2} > 226) and
({channel_2} < 246)|
!set_control|color_color|-2$
({channel_2}-227)$
!if|({channel_2} > 245) and
({channel_2} < 256)|
!set_control|color_color|-3$
((255-{channel_2}) * 2)$
begin
if channel_2 < 208 then
color_color := channel_2;
color_speed := 0;
(else)
if (channel_2 > 207) and
(channel_2 < 227) then
color_color := -1;
color_speed := 226-channel_2;
(else)
if (channel_2 > 226) and
(channel_2 < 246) then
color_color := -2;
color_speed :=channel_2-227
(else)
if (channel_2 > 245) and
(channel_2 < 256) then
color_color := -3;
</procedure>
end
Tip(s)
Links and references
- ↑ 1.0 1.1 Link Gerätebibliothek:http://www.DMXControl.de/Geraetedefinitionen/Geraetebibliothek.html
