Glossary DMXC2
From English DMXC-Wiki
Revision as of 20:59, 16 November 2013 by Steiny (talk | contribs) (→‎L)
Template:Chaptertitle DMXC
VLC icon.png This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page.
Hint:
25.5.2013: UPrenner: create the article page
Table of contents
Inhaltsverzeichnis A B C D E F G H I J K L M N O P Q R S T U V W X Y Z Ü
ArtNet
ArtNet (or Art-Net) is an IP based protocol for the assignment of large quantities of DMX information about LANs or WANs under use of the default network topology. The present ArtNet uses UDP about IP. The specification was made by the company "Artistic Licence" and is freely available in version 3 at the moment (Download). She was appreciated by bigger manufacturers.[1][2][3] The advantage of ArtNet consists that the DMX cables are replaced by Ethernetkabel in parts of the transmission path. One needs no more classic DMX transmitter at the PC with that since the signals are sent about a mostly per default available network interface. A complete show can theoretically be steered over the Internet with that. WLAN ways are more practice relevant so that the wiring can be dropped on unfavorable ways or even for the most part. Another advantage is the bi direktionale communication for re-registrations by means of RDM which, however, isn't supported of DMXControl yet. Also proprietary protocols are conceivable since the UPD protocol bi direktional is interpreted. Since the steered equipment has DMX interfaces for the most part by means of 5-pole XLR sockets furthermore, one needs another one or several so-called ArtNet knots which one, the ArtNet information in standard DMX 512 signals zurückverwandeln. So an ArtNet knot gets the signals about a network interface for one and or more DMX university verses distributes the DMX signals separated according to university verses about XLR. These Nodes even can be built themselves: Art-Net-Node für 25 Euro.
Audio cue
Audio cues permit playing an audio file in a definable length. You are usable for cues in various tools equally. The light technician also can synchronously steer audio sequences to the light with that. E.g. there is an important application for this at the theater control by means of script.
Figure 1:Create a audio cue
Figure 1: Create a audio cue
To other cues an audio cue analogously gets an eloquent name so that these are re-traceable also in the cue library. As a wave file WAVE, MP3, MP2, MP1 and OGG-Vorbis files can be used. Like other cues also can the audio cue a duration be assigned to control the temporal sequence of the cues and with that the length of the wave file as of the beginning. Has suitably to be broken off around the audio input after the adjusted time the option "after passed duration stop account". The duration also can on be limited manually to carry out the control over the "GO" button. Audio cues can be assigned to one by 16 (audio-)channels. About the channel number audio cues can be broken off by command. Siehe auch Audio manager
Audio manager
The audio manager as a drop down menu hides behind the "audio stop" button or courage button in the control center (loudspeaker with a red point). An overview has active audio streams (channels) opened out for itself there. The left symbol says to the statuses of the respective audio scene the audio stream can be manipulated with the respectively right symbol group with the usual functions break, rewinding, stop. The channels can be changed in the volume one by one and switched dumbly about orders. Several audio cues also can be on a channel.
Figure 2:View of the audio manager in the control center
Figure 2: View of the audio manager in the control center
Output plugins
The union on the side of the software which processes the generated DMX data represents a version Plugin between DMXControl and a hard or software. This mainly is DMX interfaces (transmitters) which pass the data (mostly cable-bound) on to a DMX-capable device. The union to a visualisierer or by ArtNet is but also taken by output plugins. See also Output plugins.
Termination resistor
To ensure of a loss and trouble-free assignment of the DMX signals the DMX512 protocol requires RS485 standard a terminating resistor of 120 Ohm at the end of the DMX chain between the signal leads (exact this). Feedbacks and signal reflections which could distort further sent values are prevented with that. €Zhowever, one gets her aurochs guarantee of a loss and trouble-free also by the installation of a corresponding resistance into a DMX plug between datas+ and data ), (Pin 1 and 2) produce themselves.
Bank
Banks which serve for the ready attitude of different attitudes of the same module can be laid out within certain modules. By means of commands you can change between the Banks. Banks can be made in the following modules:
DMXIn remote control
Different assignment of DMX channels
Command box (Pages)
Choice of different pages (at most 10)
Midi Fernsteuerung
Different assignment of MIDI channels
Sound Analyzer
Different assignment of settings
Submaster
Assignment of the 12 sub-masters. It is for " possible to order groups of equipment logically front ", "Audience" "hall light" for example bench parse.
Command
see Command overview
Blackout
A blackout describes turning off immediately ( or in the lighting engineering. Darken ) all light sources. Transferred to the DMX protocol this means that all dimmer channels are immediately put on 0%. A "blackout" buttone is in DMXControl in the control center. If this is activated, all channels defined as dimmer channels are backed 0% and the version closed on these channels until the blackout is lifted again.
DDF
DDF is the abbreviation of "DEVICE definition file". DDFs are used by DMXControl to describe information about the used equipment in the XML format. Among other things the channel occupancy of the device, the layout of the control window as well as further information are contained in a DDF. The DDFs are in the sub-folder "DEVICEs" of the DMXControl contents directory. The accompanying device image files which are shown on the graphical view lie name in another sub-folder „Images“. A DDF library is installed per default. For the construction of DDFs see DDF basics.
DMX512
The DMX512 protocol 1986 of the USITT, an American organization was defined, which deals among others with theater technology (short DMX). With various improvements it is also standardized in Germany since 1994 (DIN 56930/Teil2). DMX stands for D 'igital', 'M ultiple 'X, which means that the signals are transferred digitally over a line to the dimmers and other devices. Unlike this the earlier ones had systems one analogous line each for every single device. Since the equipment is switched at DMX behind each other, one also talks about a DMX chain (engl. daisychain). In a plain verse attached equipment has a clear start address between 1 and 512 everybody. However, at most 32 equipment only should be attached at a DMX rope since otherwise the burden on the line gets too big. Remedial action then can be taken with amplifiers or splinters. A value between 0 and 255 sent can weden over the DMX protocol on every channel in a cycle. The meaning of the value isn't defined in the DMX protocol but depends on the device individually. Protected two wire lines shall be used for DMX with 5-pole XLR plugs. However, in the practice one finds 3-pole XLR verb Indians at a favorable equipment particularly in front of - these aren't then, however, standard-compliant and mustn't bear the name DMX512.
DMXC plugin
DMXControl defines two kinds of Plugins for the expansion of the functionality:
  • Outout plugins to the support of different new DMX interfaces
  • Application plugins for inserting new tools and functions in DMXControl
DMX interface
A "DMX interface" (also frequently called "DMX transmitter") represents the hardware interface between PC and the DMX universe. There are the values produced by DMXControl on the DMX chain. The transmitters can parallel or about USB serially internally be attached at the PC. One needs a DMX interface for productive use of DMXControl or the real drive of a DMX-capable device, in principle the program works completely (primarily for exercise purposes) also without interface. DMXControl uses output plugins to mention different DMX transmitters with a uniform interface. A complete list of the DMX interfaces supported by DMXControl is found on our [dmxcontrol. de/unterstuetzte-interfaces. html|Website]. The DMXControl interface specification is available so that you your self can make an output plugin. At the program start DMXControl is looking for files in his contents directory with the ending "*.out.dll" which the output plugins represent. One then can activate and configure the required plugins over the menu item of output plugins.
Dimmer channel
Channels which function as dimmers become in the DDF of the respective device by means of type=dimmer when such defines. Using this information DMXControl only can apply certain functions to channels which also steer the brightness of a device. Among other things these are:
Fade in time
One can define a one dazzling time in DMXControl for every cue around gentle fadeing to realize between cues. Be the DMX values brought closer to the stored values continuously and finally put on these during this period of time (engl. fading). The contrast to this is a sudden change of the values at a one dazzling time of 0 seconds. Which not faded are (e.g. Gobo wheels) one can fading point do for channels be defined.
Fader
A fader is a mechanical slider more classically wisely which changes an electrical resistance and is found at audio or light sound mixers, for example. The English verb to fade expresses a fluent, continuous transition between two values. This is primarily confessed dull one and dull out as volume change at the beginning and end of a piece of music. (Software-)faders are used in DMXControl mainly in the submaster. You serve to adjust exact DMX values or to realize gentle transitions between cues. Also in much DDFs faders are defined and make the attitude possible there among other things of trick and strobe speed or colors.
Color filter
A color filter is a firm intention for a lamp which shall ink her light. Color filters are usually colored plastic films. Besides that there is also dichroic filter, which consist of glass and make a considerably better filtration possible at a higher price.
Color wheel
A color wheel is often found in moving heads and other multifunction headlights. It is a plate on which glass color filters are arranged circularly and reach to the course of ray. Discreet light colors or half colors are produced by the color wheel be able to into been different.
Flash button
Flash buttons set their assigned channels temporarily (for the duration of the operation) to the maximum allowable value. This is in DMXControl by the maximum values ​​in the DDF and the Flash master defined
Device
In DMXControl the term device refers to a point in the DMX chain, where the signal is evaluated. This can happen, for example by:
  • an dimmer
  • an fog machine
  • an multi-function spotlight as moving head or scanner
  • an Application plugin
  • everything DMX can process
A device is usually (but not necessarily) physically present and responsive to the transmitted signals DMX. Devices are described by DDF, containing all the necessary information for control. In the graphical view of the Stage devices can be created, deleted, and moved in front of the background image. A click on the device icon opens the Control Panel. Devices always need a Start address.
Gobo / Gobo wheel
A gobo (Graphical optical blackout) alters the beam of a spotlight. It is a mask that can be cut out of geometric shapes, texts or images. The light beam then assumes this shape. Gobos are constructed of metal stamped from thin sheet metal or glass gobos more expensive than in combination with dichroic filters. In the headlamps often even more screens sit on a circular gobo. Depending on the rotation of the gobo wheel, there is a certain gobo in the beam, the beam then becomes the subject. Also there is the possibility to have gobos rotate around itself.
HTP
HTP stands for "highest takes precedence" (the highest value prevails ) and is usually used for dimmer channels ,e.g. To prevent flicker by parallel changes from several sources. DMXControl HTP can be applied to all channels that are marked as type="dimmer" in DDF. Thus, the highest value is always output on one channel, for example we can the sound analyzer and run at the same time can also create an effect. Would be possible that a preheat , because the value "10" would be compared to the "0" as by setting an ongoing effect. By default, the HTP mode is disabled, but can be switched to the application configuration easy. HTP / LTP processed per channel - channels in the DDF as a " dimmer type = " are registered HTP are mixed , the rest of LTP . But if you completely shut down the program configuration HTP , then dimmer channels are mixed LTP . If you have problems with "hanging " channels , which probably has to do with the HTP mode. In the channel list is displayed which channel of which was last modified mixer channel . If for example a fully wound channel of a scene , it can only be set by the next scene, or by closing the scene tools back to a lower value . When a scene fades into another , the old values ​​should also be reduced .
Preheat
The preheat (also Pre Heat) serves to increase the life of your bulbs. The lamps are not switched off completely, but always operated slightly dimmed, so that the lamp is not currently visible. In DMXControl can reach a preheat by
  • activate the HTP mode (in the program settings)
  • save a cue that contains the desired channel values ​​for the preheating and
  • this scene a command call at startup can (also program settings).
LTP
LTP stands for "latest takes precedence" (the last value prevails) and is automatically used when DMXControl for all channels that are not marked as "Dimmer". The last channel change is passed directly to the output system. If the mixer channel is closed, the state before the first change by the just closed mixer channel will be restored on each DMX channel.
Line termination
To ensure a low-loss and trouble-free transmission of the DMX signal DMX512 protocol requires a terminating resistor of 120 ohms at the end of the DMX chain between Data + and Data-(pin 2 and 3). So that feedback and to prevent signal reflections that could distort further transmitted values​​. There are to buy commercial terminators (5-7 €), but you can be prepared in a DMX connector such a device itself also through the incorporation of an appropriate resistor.
Master
Ein Master ist die letzte Instanz, die Einfluss auf das Signal nimmt, bevor es zur Ausgabe gelangt. Änderungen an einem Master Controller wirken sich synchron auf alle untergeordneten Kanäle aus bzw. geben Maximalwerte für sie vor. In DMXControl gibt es das Modul Master, in dem sich Grandmaster (Dimmer), Sekundärmaster (Dimmer), Flashmaster (Maximalwert für Flashbutton) und Speedmaster (Geschwindigkeit von Effekten und Einblendzeiten) befinden.
Mixerkanal
DMXControl verwendet intern einen Mixer, der die DMX-Ausgaben der verschiedenen aktiven Tools sammelt und daraus die Ausgabewerte generiert, die dann auf dem jeweiligen DMX-Sender ausgegeben werden. Die unterschiedlichen Quellen (also meist Tools) werden dabei als "Mixerkanäle" bezeichnet, nicht zu verwechseln mit DMX-Kanälen. Ein Mixerkanal umfasst normalerweise den gesamten DMX-Kanalraum, den die jeweilige DMXControl-Version zur Verfügung stellt (256 bzw. 512 Kanäle). Wird ein Mixerkanal „geschlossen“, werden auch die Ausgabewerte neu berechnet. Im Mixersystem von DMXControl behält immer das Tool, das vom User als letztes bedient wurde die Controlle, bis
  • das Tool geschlossen wird,
  • ein anderes Tool bedient wird
  • das Tool zurückgesetzt wird.
Manche Tools wie der Audioplayer z.B. bieten eine Taste, mit der man das Tool rücksetzen kann (kleiner roter durchgestrichener Kreis). Beispiel: Wenn man mit der Flash Taste des Submasters einen Kanal bedient, ist der Submaster das letzte Tool, was auf den Kanal zugreift. Damit ein anderer Effekt auf diesem DMX-Kanal wieder wirkt, kann man 3 Dinge tun:
  • Das Submaster Fenster schließen,
  • den Effekt neu starten und
  • den Submaster zurücksetzen.
Mixermodus
Ein Kanal des internen Mixers kann nach 2 Vorgaben gemischt werden, diese sind LTP und HTP.
Projekt
Sie können verschiedene Projekte (Shows) generieren, speichern und (jeweils zu einem Zeitpunkt genau ein Projekt) laden. In DMXControl enthält ein Projekt alle Projektdaten, die für eine Show relevant sind. Solche Daten sind unter anderem welche DMX-Geräte verwendet werden, erstellte Szenen und Effekte, Ein- und Ausgabekonfigurationen und einiges mehr. Sie werden von den einzelnen Modulen von DMXC in einem gemeinsamen Ordner aber mit unterschiedlichen Dateiendungen gespeichert.
Darüber hinaus gibt es auch sog. globale Daten, die DMXControl projektübergreifend in einem separaten Verzeichnis ("%Appdata%/PopSoft/") speichert. Zu diesen globalen Daten gehören auch Einstellungen der MIDI- und DMX-Fernsteuerungen. Daher müssen diese Daten beim Kopieren eines Projektes auf einen anderen Computer auch mitkopiert werden. Wie das am einfachsten funktioniert, kann in Kapitel 31 nachgelesen werden.
Spektrum
Startadresse
Jedes physikalische Gerät in einer DMX-Signalkette besitzt eine sogenannte Start- oder Basisadresse. Diese wird am Gerät selbst eingestellt, idealerweise ist sie identisch mit der Startardresse des Gerätes in DMXControl. Diese Adresse bezeichnet den niedrigsten, aber nicht zwingend den einzigen, Kanal, ab dem ein Gerät die DMX-Werte verarbeitet. Ein 4-kanaliger Dimmer mit der Startadresse 5 wertet die Kanäle 5,6,7 und 8 aus, ein Movinghead kann für seine Funktionen durchaus 15 oder mehr Kanäle belegen. Es ist auch möglich, mehreren Geräten die gleiche Startadresse zuzuweisen. Dies kann zu ungewollten Resultaten führen, jedoch auch bei gleichen Scheinwerfern bewusst eingesetzt werden für synchrone Ausgaben. Wie die Startadresse eingestellt wird, hänge vom Gerät ab, beachten Sie hierbei bitte die Bedienungsanleitung des Herstellers. Template unused
Submaster
Ein Submaster ist ein Fader, der Werte von verschiedenen Kanälen gemeinsam steuern kann. Das Submaster-Konzept wird in DMXControl durch das Submaster Tool realisiert, wobei jeder Submaster aus einem Fader und einem Flashbutton besteht. Mittels eines Submasters können zum Beispiel gleiche Funktionen gebündelt werden, also alle Rot-Kanäle von 10 LED-Scheinwerfern.
Szene
Eine Show besteht aus diversen Szenen. Eine Szene ist eine momentane Einstellung aller angeschlossenen Geräte (DMX-Werte). Pro Szene kann eine Einblendzeit sowie eine Haltezeit angegeben werden, welche jedoch nur innerhalb der Szenenliste oder eines Effektes zum Tragen kommt. Werte einer Szene bleiben auf der Ausgabe aktiv, bis sie explizit überschrieben werden, beispielsweise durch eine andere Szene. Template:Bild mit Unterschrift Neben der „Einfachen Szene“ können Befehle, Bewegungs- oder Audioszenen verwendet werden. Alle Szenen werden in der Szenenbibliothek verwaltet und können von dort gewählt und wiederverwendet werden. Kompositionsszenen können beliebige Szenentypen zusammenfassen. Template unused
Szenenliste
Ü
Überblendpunkt
Der „Einsatzpunkt“ wird beim Überblenden zwischen zwei Lichtstimmungen verwendet. Während als Kanäle mit dem Attribut "fade=yes" (Dimmer) weich übergeblendet werden, müssen die übrigen Kanäle (Shutter, Goborad) an einer Stelle abrupt auf den neuen Wert gesetzt werden. Der Einsetzpunkt stellt die Stelle auf der Zeitleiste (zwischen 0 und 100% der Überblendung) dar, an der das Umschalten passiert. Auf diese Weise können Gobos entweder am Anfang oder am Ende der Einblendzeit gewechselt werden.
Referenzen
  1. ↑ Martin Ether2DMX8™. Abgerufen am 12. März 2013.
  2. ↑ JB Lightning Licon 2X. Abgerufen am 12. März 2013.
  3. ↑ Einbindung in die Open Lighting Architecture. Abgerufen am 12. März 2013.
Table of contents
