Program settings DMXC2
From English DMXC-Wiki
Revision as of 20:14, 6 November 2013 by Steiny (talk | contribs)
Template:Chaptertitle DMXC
VLC icon.png This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page.
Hint:
04.11.2013: UPrenner: work-in-progress
Table of contents
Essential attitudes can be adapted regarding the unusual features of the computer and/or the light configuration in the window program configuration.
The program configuration is divided up into 5 areas:
  • General
  • Graphical view
  • Cues/Chasers
  • Tools
  • Output
Description
Tabulator General
Figure 1:Window program settings, tab general
Figure 1: Window program settings, tab general
Setting Meaning Default comment
Performance
Update interval of the Spectrum Analyzer Time interval after which new audio data are fetched by WinAmp 50 ms A larger interval can improve performance at weak computers
Deactivating an automatic securing of the scene library The scene library is stored periodically, by activation this storage can be put down. not active At great projects with outstandingly many scenes, it can come to delays in the course of the effects by the automatic storage of the cue library sometimes.
View
Type size for extended view Type size in the graphical view at extension 8
Indication of the DMX values % Rearrangement between absolute and percent indication not active
Program startup
Execute of a command at the start of DMXControl To the start of DMXControl an command which switches on e. g. the Grundlich is executed. no command defines The command can about the DMXControl usual commands are defined. (see chapter command overview)
Deactivating safety query at program end Deactivating query when ending DMXControl not active
Other
Save color and gobo lists globally The color and gobo lists aren't stored in the project directrory, but in the DMXControl directrory . not active Farb and Gobolisten can be used in all projects
Flash "scroll lock" LED on beat Beat from the beat tool or sound analyzer flashes the "scroll lock" LED. not active
  Important hint Bei großen Projekten mit überdurchschnittlich vielen Szenen, kann es durch die automatische Speicherung der Szenenbibliothek schon mal zu Verzögerungen beim Ablauf der Effekte kommen. In diesem Fall empfiehlt sich an dieser Stelle die automatische Sicherung zu deaktivieren
Registerreiter Grafische Ansicht
Figure 2:Window program settings, tab graphical view
Figure 2: Window program settings, tab graphical view
Geräte-Popups
Beim Überstreichen mit der Maus öffen DDF-Geräte-Popups öffnen sich nicht, wenn man mit der Maus darüber fährt. nicht aktiviert
Nach Mausklick auf das Symbol öffnen DDF-Geräte-Popups öffnen sich bei Klick auf das Geräte-Icon. aktiviert
Schließen nach:        ms Zeit bis zum Schließen der DDF-Geräte-Popups nachdem die Maus das Popup verlassen hat. 1 sec.
Symbole
Symbolgrösse in der grafischen Ansicht Größe der Icons in der gafischen Bühnenansicht in Pixeln 32 pixel.
Beim Zoomen ebenfalls vergrößern. Ions beim Zoomen der grafischen Ansicht ebenfalls vergrößern nicht aktiviert
Darstellung der Farbe statt Grafik verwenden Bei Aktivierung wird bei LED-RGB-Geräten statt des Icons ein Kreis in der eingestellten LED-Farbe dargestellt. nicht aktiviert
Gerätenamen & -adresse anzeigen Die Gerätenamen und -adressen werden zusätzlich zu den Icons in der grafischen Bühnenansicht angezeigt nicht aktiviert
Registerreiter Szenen/Effekte
Figure 3:Window program settings, tab cues/chasers
Figure 3: Window program settings, tab cues/chasers
Szenen
Standard-Einsprungpunkt bei nicht-fadenden Kanälen Über den Slider kann festgelegt werden ab welchem Punkt der Kanal eingeschaltet wird. 50%
Nicht warnen wenn alle Kanäle gespeichert werden. Beim Speichern von allen Kanälen erfolgt durch DMXControl eine Warnung, da hierdurch die Datenbank auch größer wird. Hier kann diese Warnung abgestellt werden und darurch effektiver gearbeitet werden. nicht aktiviert
Effekte
Effekte durch Doppelklick startbar. Er möglicht das starten im Effektsequencer durch einen Doppelklick. nicht aktiviert
Ungruppierte Effekte als eigenständige Guppe behandeln Alle Effekte die keiner Gruppe zugeordnet sind bilden bei Aktivierung eine Eigenständige Gruppe. nicht aktiviert
Gruppennamen rechstbündig ausrichten Richtet, bei Aktivierung, die Gruppennamen rechtsbündig im Effktsequencer-Fenster aus, statt direkt hinter die Effektnamen aktiviert
Registerreiter Tools
Figure 4:Window program settings, tab tools
Figure 4: Window program settings, tab tools
Sound Analyzer
Quelle VBVis-Plugin Wenn der Radiobutton VBVis-Plugin aktiviert ist werden die Audiodaten für das BeatTool und den Sound Analyzer über dieses Plugin in Winamp nach DMXControl importiert. aktiviert
Quelle AVS-Plugin Wenn der Radiobutton AVS-Plugin aktiviert ist werden die Audiodaten für das BeatTool und den Sound Analyzer über dieses Plugin in Winamp nach DMXControl importiert. nicht aktiviert
Registerreiter Ausgabe
Figure 5:Window program settings, tab output
Figure 5: Window program settings, tab output
DMX-Mixer
Highest takes precendence-Mischung (HTP) deaktivieren Mit dieser Option, kann zwischen LTP und HTP DMX-Mischung umgeschaltet werden. aktiviert
DDFs können Kanalwerte begrenzen (MinValue/MaxValue) Bei Aktivierung dieser Option werden die Min- und MaxValue Werte aus den DDF's übernommen und für die Ausgabe mit einbezogen. nicht aktiviert
Werte aus allen Quellen auf gewählten Geräte anwenden Wenn diese Option aktiviert ist, führen gruppierte Geräte in der grafischen Bühnenansicht beim Ablauf von Szenen die gleichen Abläufe aus. nicht aktiviert
Table of contents
