Device Manager DMXC3
From English DMXC-Wiki
Revision as of 18:00, 1 March 2025 by Jkuehn (talk | contribs) (Created page with "{{Manual Header | Type = DMXC3 Main-Software | Version = 3.2.2}} With the help of the dialog {{Manual Windowcaption|Add Device}}, so-called Device Definition Files (DDFs) can be added to a project, allowing the {{Manual Windowcaption|Hardware Abstraction Layer (HAL)}} in DMXControl 3 to know which {{Manual Windowcaption|Devices}} are addressed on which DMX channels and which functions the...")
Books.png Article describe
DMXControl 3.2.2
Stand: 01.03.2025
Table of contents
With the help of the dialog Add Device, so-called Device Definition Files (DDFs) can be added to a project, allowing the Hardware Abstraction Layer (HAL) in DMXControl 3 to know which Devices are addressed on which DMX channels and which functions they provide. Without the appropriate DDFs for the devices to be controlled, DMXControl 3 can only operate with limited functionality.
__TABLE OF CONTENTS__
1View of the "Add Device" dialog.
1 View of the "Add Device" dialog.
The Add Device dialog is always required when devices need to be added for the first time in a new, empty project, or when additional devices need to be included in an existing project. This is where the initial patch of required devices to their respective DMX addresses takes place.
The different icons before a DDF clearly show where the respective DDF comes from. Furthermore, all DDFs used in the current project are grouped into a common folder, should you need additional devices of the same type in the same DMX mode. For frequently used devices, the Favorites folder is available.
110px | link= | Wichtiger Hinweis Changes to DMX addresses for devices that are already integrated into the project should not be made in the Add Device dialog but rather through the properties of the respective device or via the Patching dialog.
Important Features
Add Additional DDFs
DMXControl 3 comes with only a small selection of DDFs, meaning that due to the large number of available devices, DDFs for your own devices are often missing. To use custom-created DDFs or DDFs manually downloaded from the DDFLibrary in DMXControl 3, you need to place them in the directory accessed via the "Own DDFs" link in the Start menu (see Figure 2).
However, this directory can also be accessed via the Windows Explorer at the path "C:\Users\{USERNAME}\AppData\Roaming\DMXControl Projects e.V\DMXControl\", where "{USERNAME}" refers to the name of the current user of the PC. As a shortcut, you can also reach this directory by entering "%AppData%\Roaming\DMXControl Projects e.V\DMXControl\" in the address bar of Windows Explorer.
You then save the xml file of the DDF in this directory. When using it for the first time, you may need to create the directories "Images" for the device images and "Icons" for the Gobos' icons, as shown in Figure 3. DDFs downloaded manually as a zip archive from the DDFLibrary need to be unpacked in this directory, and the image files for devices and icons must be placed in their respective folders. DMXControl 3 automatically handles the latter when you select a DDF directly from the DDF Library dialog.
The directory "UserDevices" can also be used to store DDFs that you are currently creating and testing their functionality.
Whether modifying newly created DDFs or adding additional ones: the contents of the Add Device dialog are updated with each reopening. Therefore, DMXControl 3 can remain open during this process.
2Shortcut in the Start menu to access the folder for user-created DDFs.
2 Shortcut in the Start menu to access the folder for user-created DDFs.
3User DDFs in the "UserDevices" directory.
3 User DDFs in the "UserDevices" directory.
Types of DDFs
The Add Device dialog gives access to three types of DDFs, which are stored in different directories and treated with different priorities when adding additional devices to an existing project.
Category Icon Description Location Priority
Project-DDF DMXC3 Icon V-Collection suitcase2.png Includes all DDFs required for the proper functioning of the current project "{PROJECT-ZIP}\LibDevices"
"{PROJECT-ZIP}\UserDevices"
Highest priority in the current project,
not present in new projects
User-DDFs DMXC3 Icon V-Collection pawn blue.png User-created DDFs "{APPDATA}\DMXControl Projects e.V\DMXControl\Kernel\UserDevices\" Medium priority in the current project,
highest priority in new projects
Lib-DDFs DMXC3 Icon V-Collection earth.png Standard DDFs delivered by the installer "{PROGRAM_DIRECTORY}\Kernel\LibDevices\" Lowest priority in the current project,
medium priority in new projects
DDFs downloaded via the DDF Library "{APPDATA}\DMXControl Projects e.V\DMXControl\Kernel\LibDevices\"
110px | link= | Wichtige Referenz The meaning of the directories {PROGRAM_DIRECTORY}, {APPDATA} and {PROJECT-ZIP} in the context of DMXControl 3 is described in the article DDF Introduction.
110px | link= | Achtung, wichtiger Hinweis! All DDFs delivered by the installer and placed in the directory "{PROGRAM_DIRECTORY}\Kernel\LibDevices\" are completely overwritten with each update or reinstallation. Please use the "UserDevices" directory for your own DDFs, which can be accessed via the "Own DDFs" link in the Start menu of Windows.
Controls
The Add Device dialog is split into two parts. On the left side, there is a list of all DDFs, grouped by Favorites, Project-DDFs (for an existing project), and all available DDFs. All DDFs are listed according to their respective manufacturers and, if available, the corresponding DMX modes. When a DDF is selected, some device properties are displayed at the bottom. On the right side of the window, you define the name, number, and start address for the new device.
Scope and Structure of the List
DMXControl 3 distinguishes between three types of DDFs:
  1. DDFs for a specific device from a specific manufacturer with a specific DDF mode
  2. DDFs for a specific device, but without a clear manufacturer association
  3. Generic DDFs without reference to a specific device or manufacturer
Device-Specific DDFs
DDFs created for a specific device with a specific DMX mode from a specific manufacturer are categorized accordingly and can be found by those search terms. Generally, the respective DDF includes all the functions of the device that could be controlled by DMXControl 3 at the time of creation.
DDFs Without Specific Manufacturer
Many devices on the market have an unclear or no defined manufacturer. To keep the list of available DDFs structured, these DDFs are collected in a common folder.
110px | link= | Wichtiger Hinweis DDFs for devices without a clearly identifiable manufacturer can be found in the list under the folder Various.
General DDFs
DMXControl 3 also includes a number of general or generic DDFs that are not created for a specific device. These include:
  • Simple dimmers
  • Switches
  • DDFs for LEDs in various forms such as RGB, RGBW, with or without dimmer, strobe channel, etc.
Typical examples include dimmer packs or LED strips. For each controllable output, you add the corresponding DDF to the project, such as
  • 4 times the simple dimmer (for example, in 8-bit resolution) for a 4-channel dimmer pack
  • 170 times the RGB DDF for an LED strip, where the 170 pixels can be individually controlled
110px | link= | Wichtiger Hinweis All available general/generic DDFs can be found in the list under the folder Generic.
Usage
Open Device Manager
4Opening the Device Manager.
4 Opening the Device Manager.
To add devices, open the Add Device dialog. This can be done in three ways:
  • via the menu entry « Add Device » in the context menu of the Device folder in the Project Explorer, or
  • using the [Add Device] button in the Project Explorer menu bar, or
  • via the context menu in the Stage View
Add Devices
To add one or more devices, select the correct DDF or search for it using the search function. Once the desired device is selected, you can enter the quantity and adjust the name if needed. In the DMX settings area, define the start address (DMX start address) for the first device and whether a certain number of DMX channels should be left between devices (DMX space). The third part assigns the devices to a Device Group. If you want to add more than one device, this setting becomes active, and DMXControl suggests creating a new device group. You can change this name or select an existing device group from the dropdown to which the new devices should be added. By clicking the [Add] button, DMXControl 3 applies the previously set information. Afterward, you can directly add more devices. Once all devices are selected, click on the [Close] button.
Favoriten
Der Ordner Favoriten sammelt alle Geräte, die regelmäßig für neue Projekte genutzt werden. Welche Geräte dort aufgeführt werden, kann man selbst bestimmen. Man sucht ein bestimmtes Gerät in der Liste und wählt im Kontextmenü den Eintrag « Zu Favoriten hinzufügen (Add to favorite) ». Bereits im Favoriten-Ordner vorhandene Geräte lassen sich über den Eintrag « Aus Favoriten entfernen (Remove from favorites) » entfernen.
Template:Bild mit Unterschrift Template:Bild mit Unterschrift
Bild: Es ist zu beachten, dass die Favoritenliste lokal auf dem PC gespeichert wird und somit bei der Nutzung eines anderen PCs einen anderen Umfang hat.
Fehlerhafte DDFs
Beim Hinzufügen von DDFs können zwei Arten von Fehlern auftreten:
  1. In der Logik des DDFs ist ein Fehler. Die betroffene Stelle im XML-Code des DDFs wird in einem weiteren Fenster anzeigt, sobald man mit dem Klick auf [Hinzufügen] das Gerät zum aktuellen Projekt hinzufügen möchte.
  2. Im Verzeichnisbaum erscheint ein weiterer Eintrag "Corrupted DDFs". Hier liegt ein schwerer Fehler im XML-Code vor, den man extern zum Beispiel mit Notepad++[1] und dem dort verfügbaren Plugin XML-Tools[2] prüfen muss.
  1. ↑ Notepad++ ist ein freier Text- und Quellcodeeditor. Weitere Informationen auf der Herstellerseite: https://notepad-plus-plus.org/
  2. ↑ Installationsanleitung für das Plugin XML-Tools mit Hilfe des integrierten Pluginadministrator von Notepad++: https://community.notepad-plus-plus.org/topic/16983/xml-tools/2
Videotutorials
Geräteverwaltung und Patching
Kategorie: Handbuch DMXControl 3
