In the Application and Project Settings both the settings for the entire program and the settings for projects are defined.
In DMXControl 3, there are three types of settings:
- Application Settings: These define the general settings and behavior of the software.
- Default settings for a new project: All settings related to the assigned entries apply to a new, empty project.
- Default settings for the current project: These set all defaults for the currently loaded project. These settings are also accessible through the context menu of the respective main entry in the Project Explorer.
| The defaults from the Application Settings and Default settings for a new project are only stored locally on the respective PC. When switching to another PC, it must be checked whether the settings meet the requirements. |
Available Options
General
Settings for the Kernel
| Setting | Possible Parameters | Default value | Description | |
| English GUI | ||||
| General | ||||
| DMX framerate | Any numerical value | 30 | ||
| Cyclic resend full universe | Yes / No | No | ||
| Freeze on shutdown | Yes / No | No | When Freeze on shutdown is activated, the DMX output will not be overwritten, so the interfaces and connected devices will play back the last active scene after the kernel is stopped. | |
| Programmer-Priority | Programmer priority | Programmer Normal |
Normal | |
| Fogger priority | Fogger Normal |
Fogger | ||
| Ask all sessions on project close | Yes / No | Yes | ||
| Connection timeout | Any numerical value | 1000 | ||
| Parallelization | ||||
| DMX parallel mode | None Allowed Recommended Forced |
Allowed | None: No parallelization Allowed: Parallelization is possible if a threshold of values to be calculated is exceeded. The threshold is adjustable in the settings file. The current default value is 20, meaning if you have 20 values that change at once, parallelization will occur. Recommended: Automatic parallelization when the threshold of ten values changing simultaneously is exceeded. Forced: Always parallelize. | |
| DMX parallel count | Any numerical value | 2 | ||
| Input assignment parallel count | Any numerical value | 4 | ||
| Project autosave | ||||
| Enabled | Yes / No | No | Activates (True) or deactivates (False) the autosave function for projects in DMXControl 3. | |
| Interval | Time value in minutes | 15 | Defines the interval at which the project will be automatically saved. | |
| Suspend on activity | Yes / No | No | ||
| Keep files | Any numerical value | 5 | Specifies how many backup versions of the project should be kept. | |
| Maximum MB | Numerical value in MB | 500 | Specifies how much disk space the backup files can take. If the set limit is exceeded, the number of available backup versions will decrease. | |
| Network | ||||
| Kernel send broadcast | Yes / No | Yes | Activates (True) or deactivates (False) the broadcast sending mode of the kernel. | |
GUI Settings
| General | ||||
| Load last layout | Ask Yes No |
Ask | Ask: Every time the project is loaded, it will ask whether the last saved window layout in the project should be opened. Yes: The last saved window layout in the project will always be loaded. No: The GUI will retain the current window layout. | |
| Session handling on disconnect | Suspend Close Ask |
Suspend | ||
| Save project on close | Ask Yes No |
Ask | Ask: Every time DMXControl 3 is closed, you will be asked if you want to save the current project. Yes: The project will always be saved when closing. No: GUI and kernel will be closed directly. | |
| Shutdown server on close | Ask Yes No |
Ask | Ask: The kernel will only shut down after closing the GUI if explicitly requested. Yes: The kernel will always shut down when the GUI is closed. No: The kernel will remain active in the background and may need to be manually shut down later. | |
| Network | ||||
| GUI send broadcast | Yes / No | Yes | Activates (True) or deactivates (False) the broadcast sending mode of the GUI. | |
