Cuelist (Options) DMXC3
From English DMXC-Wiki
Revision as of 02:04, 4 March 2025 by Jkuehn (talk | contribs) (Created page with "{{Manual Header | Type = DMXC3 Main-Software | Version = 3.2.3}} Overview of the settings (Properties) for the {{Manual Windowcaption|Cuelist}}. === Behavior of the Cuelist and Cues === {{DMXC3 Manual-Tableheader Settings | en}} {{DMXC3 Manual-Tablesection | S1 | 5 | General}} | Cuelist Number || Any numerical value || || |- | Priority || <code>-127</code> to<br /> <code>127</code> || 0 || Specifies which Cuelist should be executed first when multip...")
Books.png Article describe
DMXControl 3.2.3
Stand: 04.03.2025
Table of contents
Overview of the settings (Properties) for the Cuelist.
Setting Possible Parameters Default value Description
English GUI
General
Cuelist Number Any numerical value
Priority -127 to
127
0 Specifies which Cuelist should be executed first when multiple Cuelists address the same parameters of a device.
Mixing Mode LTP
HTP
LoTP
LTP
Source for LTP priority Go of cuelist
Go of single cue
Go of cuelist
Show programmer filter "True"
"False"
"True"
Ending the Cuelist
Release time Any time value 0 ms Determines the duration of the fade when ending a Cuelist.
Release at end mode manual only
with go
when last cue ends
manual "Manual only": The Cuelist can only be ended in the Cuelist Editor by the Stop button or in the Input Assignment by setting the value true or 1 at the Cuelist Node's input.
"With go": Once all cues in the Cuelist have been executed, a further click on Go will end it.
"When last cue ends": The Cuelist is automatically ended when the last cue has been fully executed.
Reset when released "True"
"False"
"True"
Scene Playback
Play Mode Once
Loop
Random
Bounce
Once
Beat source Manual beat
Speedmaster 1
Speedmaster ...
Speedmaster 1
Tracking "True"
"False"
"True" "True": A parameter like the brightness of a device is maintained across multiple cues until it is explicitly changed by a subsequent cue.
"False": If a parameter like the desired brightness of a device is to be maintained across multiple cues, it must be explicitly set in each cue. If the parameter is not included in the cue, the device will return to its default state.
Go to time Any time value 1 s
Use cue time as go to time "True"
"False"
"False" "False": When directly calling the cue via Go To, the fade time set in Go To is used. Any fade times or delays manipulated by Fanning are ignored when fading in.
"True": Fading in the cue via Go To includes the fanned fade times and delays, just as with the regular playback sequence of the entire Cuelist.
Go back time Any time value 1 s
Use cue time as go back time "True"
"False"
"False" Behavior is the same as for Go to time.
ip trigger value at first cue "True"
"False"
"False" "True": When starting the Cuelist, the trigger values set for the first cue are ignored.
"False": When starting the Cuelist, the trigger values set for the first cue are executed before the scene is called.
Autoprepare "True"
"False"
"False"
Go next behaviour
Start cuelist "True"
"False"
"True"
Always use next index "True"
"False"
"False"
Visible Columns in the Cuelist Editor
English GUI
Progress "True"
"False"
"True" Displays the corresponding column (True) or hides it (False). For the meaning of the columns, see the previous section about the Cuelist Editor interface.
Number "True"
"False"
"True"
Trigger "True"
"False"
"True"
Trigger value "True"
"False"
"True"
Name "True"
"False"
"True"
Fade "True"
"False"
"True"
Delay "True"
"False"
"True"
Active "True"
"False"
"True"
Autoprepare "True"
"False"
"True"
Comment "True"
"False"
"True"
Fade down "True"
"False"
"False"
Delay down "True"
"False"
"False"
Take fades "True"
"False"
"True"
Defaults for New Cues
English GUI
Active source Set in defaults
Last set
set in defaults
Active "True"
"False"
"True"
Autoprepare source Set in defaults
Last set
Set in defaults
Autoprepare "True"
"False"
"True"
Comment source Set in defaults
Last set
Set in defaults
Comment Any text Empty
Delay time source Set in defaults
Last set
Set in defaults
Delay time Time value in milliseconds 0
Delay down time source Set in defaults
Last set
Set in defaults
Delay down time Time value in milliseconds Empty
Fade time source Set in defaults
Last set
Set in defaults
Fade time Time value in milliseconds 2000
Fade down time source Set in defaults
Last set
Set in defaults
Fade down time Time value in milliseconds Empty
Name source Set in defaults
Last set
Set in defaults
Name Any text New cue
Take fade source Set in defaults
Last set
Set in defaults
Take fades "True"
"False"
"False"
Trigger source Set in defaults
Last set
Set in defaults
Trigger Manual
Beat
Follow
Wait
One shot
Real time clock (rtc)
Timecode
Manual
Trigger value Any value 1
