Device (Options) DMXC3
From English DMXC-Wiki
Revision as of 02:11, 4 March 2025 by Jkuehn (talk | contribs) (Created page with "{{Manual Header | Type = DMXC3 Main-Software | Version = 3.3.0}} Overview of settings (Properties) for {{Manual Windowcaption|Devices}}. {{DMXC3 Manual-Tableheader Settings | en }} {{DMXC3 Manual-Tablesection | S1 | 5 | GUI Properties }} {{DMXC3 Manual-Tablesection | S2 | 5 | Stage View }} | Display type || {{Manual Fields|Image}}<br/> {{Manual Fields|Preview}} <br/> {{Manual Fields|Custom}} || {{Manual Fields|Preview}} || {{Manual Fields|Image}}: Disp...")
Books.png Article describe
DMXControl 3.3.0
Stand: 04.03.2025
Table of contents
Overview of settings (Properties) for Devices.
Setting Possible Parameters Default value Description
English GUI
GUI Properties
Stage View
Display type "Image"
"Preview"
"Custom"
"Preview" "Image": Displays the image of the device.
"Preview": Displays the current output.
"Custom":
Position X-coordinate
Y-coordinate
variable Specifies the position of the icon in the respective stage view.
Size 32; 32 Specifies the icon size for the respective stage view.
Kernel Properties
General Settings
Name Name of the device.
Device number Internal number of the device.
Image Here, the image of the device can be set. By default, the image specified in the DDF is displayed here.
Enabled "True"
"False"
"True" "True": Device is enabled.
"False": Device is disabled.
DMX start address DMX start address of the device.
DMX address count Displays the number of occupied DMX channels. This option cannot be changed and is defined by the DDF.
DDF source file Displays the filename of the DDF.
Color Default color for the device.
Electrical Power
Static wattage Specifies the static power consumption of the device, for example, a 250W MSD lamp plus a 20W device base load.
Dimmer wattage Specifies the dynamic power consumption of the device, for example, a 50W LED.
Device Properties
Dimmer
Mixer Mode "LTP"
"HTP"
"LoTP"
"LTP" Mixer mode for the device's dimmer channel.
Preheat 0 to 100 0 Sets a permanent minimum brightness for the dimmer, so that conventional halogen lamps do not cool down.
Limit 100 to 0 100 Maximum brightness for the dimmer, which cannot be exceeded.
Dimming curves "Gamma 1.5" ...
"Linear"
"S-Curve"
"Square"
"Square inversed"
"Switch"
"Linear" Emulation of different dimmer curves.
Strobe
Autoprepare "True"
"False"
"True" Enables or disables the Autoprepare function for the strobe.
Color
Autoprepare "True"
"False"
"True" Enables or disables the Autoprepare function for the color.
Default color Any color White Defines the default color for the device after opening the shutter and raising the dimmer.
White Automix Mode "None", "Add", "Only white" "Only white" Mixing behavior for the color white.
Amber Automix Mode "None", "Add", "Only white" "Add" Mixing behavior for the RGB+ color amber.
UV Automix Mode "None", "Add", "Only white" "Add" Mixing behavior for the RGB+ color ultraviolet.
Color Temperature
Autoprepare "True"
"False"
"True" Enables or disables the Autoprepare function for the color temperature.
