Speed Master (Executor) DMXC3
From English DMXC-Wiki
Revision as of 00:33, 5 March 2025 by Jkuehn (talk | contribs) (Created page with "{{Manual Header | Type = DMXC3 Main-Software | Version = 3.3.0}} In the area of {{Manual Windowcaption|executors}} in DMXControl 3, there is a variant for displaying a {{Manual Windowcaption|speed master (Speed Master)}} on the executor track. Using the {{Manual Windowcaption|speed master}}, the repetition speed of effects as well as the tempo for "switching" beat-controlled cue lists (cuelists) is influenced. ''For det...")
Books.png Article describe
DMXControl 3.3.0
Stand: 05.03.2025
Table of contents
In the area of executors in DMXControl 3, there is a variant for displaying a speed master (Speed Master) on the executor track. Using the speed master, the repetition speed of effects as well as the tempo for "switching" beat-controlled cue lists (cuelists) is influenced. For details, see speed master.
The variant for the speed master provides several buttons and faders to control it accordingly. Additionally, there is a tailored variant for displaying the speed master. In the settings of the associated executor, there are the following options to assign actions to the faders and buttons:
Group Action Dflt.- Value Description
English GUI
Fader Master Yes Yes Controls the value of the assigned speed master (Speed Master).
Button Double Yes Yes Doubles the current BPM value.
Half Yes Yes Halves the current BPM value of the speed master.
Learn Yes Yes Determines the new BPM value by pressing the button multiple times.
Sync Yes Yes Synchronizes the speed master.
R.M.O.C Retains the current factor when learning another BPM value.
Stomp Temporarily sets the BPM value to the minimum value, with already started fades (e.g., in cuelists) still being completed.
For the executor type speed master, there are also the following settings that influence the interaction with the assigned speed master. These can be found in the properties of each executor:
Setting Possible Parameters Default value Description
English GUI
Toggle Stomp "True"
"False"
"False" "False": The button works as a push-button, so the action is only performed when pressed and held.
"True": The button is configured as a toggle button.
