Overview of the settings (Properties) for the Cuelist.
Behavior of the Cuelist and Cues
| Setting | Possible Parameters | Default value | Description | |
| English GUI | ||||
| General | ||||
| Cuelist Number | Any numerical value | |||
| Priority | -127 to127 |
0 | Specifies which Cuelist should be executed first when multiple Cuelists address the same parameters of a device. | |
| Mixing Mode | LTP HTP LoTP |
LTP | ||
| Source for LTP priority | Go of cuelist Go of single cue |
Go of cuelist | ||
| Show programmer filter | "True" "False" |
"True" | ||
| Ending the Cuelist | ||||
| Release time | Any time value | 0 ms | Determines the duration of the fade when ending a Cuelist. | |
| Release at end mode | manual only with go when last cue ends |
manual | "Manual only": The Cuelist can only be ended in the Cuelist Editor by the Stop button or in the Input Assignment by setting the value true or 1 at the Cuelist Node's input. "With go": Once all cues in the Cuelist have been executed, a further click on Go will end it. "When last cue ends": The Cuelist is automatically ended when the last cue has been fully executed. | |
| Reset when released | "True" "False" |
"True" | ||
| Scene Playback | ||||
| Play Mode | Once Loop Random Bounce |
Once | ||
| Beat source | Manual beat Speedmaster 1 Speedmaster ... |
Speedmaster 1 | ||
| Tracking | "True" "False" |
"True" | "True": A parameter like the brightness of a device is maintained across multiple cues until it is explicitly changed by a subsequent cue. "False": If a parameter like the desired brightness of a device is to be maintained across multiple cues, it must be explicitly set in each cue. If the parameter is not included in the cue, the device will return to its default state. | |
| Go to time | Any time value | 1 s | ||
| Use cue time as go to time | "True" "False" |
"False" | "False": When directly calling the cue via Go To, the fade time set in Go To is used. Any fade times or delays manipulated by Fanning are ignored when fading in. "True": Fading in the cue via Go To includes the fanned fade times and delays, just as with the regular playback sequence of the entire Cuelist. | |
| Go back time | Any time value | 1 s | ||
| Use cue time as go back time | "True" "False" |
"False" | Behavior is the same as for Go to time. | |
| ip trigger value at first cue | "True" "False" |
"False" | "True": When starting the Cuelist, the trigger values set for the first cue are ignored. "False": When starting the Cuelist, the trigger values set for the first cue are executed before the scene is called. | |
| Autoprepare | "True" "False" |
"False" | ||
| Go next behaviour | ||||
| Start cuelist | "True" "False" |
"True" | ||
| Always use next index | "True" "False" |
"False" | ||
Visible Columns in the Cuelist Editor
| English GUI | |||
| Progress | "True" "False" |
"True" | Displays the corresponding column (True) or hides it (False). For the meaning of the columns, see the previous section about the Cuelist Editor interface. |
| Number | "True" "False" |
"True" | |
| Trigger | "True" "False" |
"True" | |
| Trigger value | "True" "False" |
"True" | |
| Name | "True" "False" |
"True" | |
| Fade | "True" "False" |
"True" | |
| Delay | "True" "False" |
"True" | |
| Active | "True" "False" |
"True" | |
"True" | |
| Comment | "True" "False" |
"True" | |
| Fade down | "True" "False" |
"False" | |
| Delay down | "True" "False" |
"False" | |
| Take fades | "True" "False" |
"True" |
Defaults for New Cues
| English GUI | |||
| Active source | Set in defaults Last set |
set in defaults | |
"True" | |
| Autoprepare source | Set in defaults Last set |
Set in defaults | |
"True" | |
| Comment source | Set in defaults Last set |
Set in defaults | |
| Comment | Any text | Empty | |
| Delay time source | Set in defaults Last set |
Set in defaults | |
| Delay time | Time value in milliseconds | 0 | |
| Delay down time source | Set in defaults Last set |
Set in defaults | |
| Delay down time | Time value in milliseconds | Empty | |
| Fade time source | Set in defaults Last set |
Set in defaults | |
| Fade time | Time value in milliseconds | 2000 | |
| Fade down time source | Set in defaults Last set |
Set in defaults | |
| Fade down time | Time value in milliseconds | Empty | |
| Name source | Set in defaults Last set |
Set in defaults | |
| Name | Any text | New cue | |
| Take fade source | Set in defaults Last set |
Set in defaults | |
"False" | |
| Trigger source | Set in defaults Last set |
Set in defaults | |
| Trigger | Manual Beat Follow Wait One shot Real time clock (rtc) Timecode |
Manual | |
| Trigger value | Any value | 1 |
