Here are explanations of the assigned keys in DMXControl 3 and useful working aids.
Key Assignments
Stage View
- Strg / Ctrl: Select multiple devices. The order of selection is important.
- F (Fanning): By pressing and dragging the mouse, the devices are aligned linearly to each other.
- C (Circle -> Circle): By pressing and dragging the mouse, the devices are arranged in a circular pattern.
- M (Matrix): By pressing and dragging the mouse, a matrix is created from the selected devices.
Cuelist
Individual cues can be copied with "Strg + C" and pasted into other positions (even in other cuelists) with "Strg + V" . The paste action always occurs above the selected cue. Note for version 3.0.1: The paste function only works if the cuelist already contains at least one cue!
Kernel
- Strg + C: Shutdown Kernel
Working Aids
Cuelist
In the tables of a cuelist, familiar actions from Excel can also be used. For the "Trigger Value" or "Fade" columns, it is possible to "copy down" a value. To do this, select the first cell to copy, then drag with the mouse down to the desired end position. By using the shortcut "Strg+U," the first value will be copied to all the other selected cells.
Cell selection can also be done via the keyboard. Click on the cell to copy, then hold down the Shift key and press the "down arrow" key.
The default settings for new cuelists can be configured in a project by right-clicking on "Cuelists" in the Project Explorer and selecting "Properties" at the bottom. This opens the "SceneList Project Default Configuration" window.
